Tool Talk Discussion Forum
Truck Transmission PTO
jhill
11-02-2004 16:11:32
I am putting a samll dump truck using a Ford F-350. I need a transmission PTO to drive a hydraulic pump. The transmission has a six bolt cover on the side. Are all the six bolt Chelsea ptos the same or is the gearing different? Are new gears expensive? Any other info would be helpful.
Thanks
Jerry
LOUIS SMITH
11-10-2005 05:39:19
 Re: Truck Transmission PTO in reply to jhill, 11-02-2004 16:11:32
i AM LOOKING FOR A PTO TO. i HAVE FOND OUT THAT THE NEWER TRUCKS ARE DIFRANT A LOT OF CHANGES . BUT I HAVE AND OLDER ONE HERE. I NEED ZF PART#[1307 050 042] RATIO 5.72-0.76 1989 FORD SUPER DUTY TRUCK. HAVE YOU FOUND ONE FOR YOURS MAYBE IN YOUR HUNT YOU MIGHT BE ABLE TO HELP ME TO FIND MY PTO. THE ONE I GOT MIGHT BE THE ONE YOU NEED?
Butcher
11-03-2004 18:29:45
I have 4 trucks with a 12 volt pump on them. They will lift all you can haul. Push the button and let it go. Way easier to use and alot cheaper than the pto.
jhill
11-03-2004 19:06:38
 Re: Truck Transmission PTO in reply to Butcher, 11-03-2004 18:29:45
zbutcher
I have thought about this but people I talked to said they pump too slow. I have a 3-4 yd box I am going to use with about a 5 inch cylinder. What size boxes do your trucks have. I agree it is alot simpler and cheaper. Just want to be sure I get good performance
Butcher
11-03-2004 19:26:59
 Re: Truck Transmission PTO in reply to jhill, 11-03-2004 19:06:38
These are all on 10 foot dumps. All 1 ton trucks. These are used for landscaping bussiness. We regularly haul 3 tons of rock or dirt or what ever on them. As far as pumping to slow I will have to dis agree. Even if they were alittle slow the fact that you can hold the button down and move the truck to spread material and still use the clutch without interfering with the hoist is a big plus. I can honestly say that I have never had a problem with one. Others might feel differantly but I use them on a daily basis.
jhill
11-04-2004 12:24:24
 Re: Truck Transmission PTO in reply to Butcher, 11-03-2004 19:26:59
Thanks for the info. I am going to use mine for the same purpose. I will look into it further.
DH in Carolina
11-04-2004 13:09:38
 Re: Truck Transmission PTO in reply to jhill, 11-04-2004 12:24:24
I have an electric pump on a 12 foot flat bed dump and never have any problems with it. It will dump anything that I can haul and is pretty fast also. Danny Hearl
Michael in PA
11-03-2004 15:34:25
Just a thought: there are 12V DC hydraulic pumps (Northerntool.com has them for under $500). Don't know how many amps they draw, but they do have built in valves and even a remote control.
Red Dave
11-03-2004 06:28:46
From my days of working on fire trucks with PTO driven pumps, I remember that one thing you need to be sure of is PTO direction. They don't all turn the same. Make sure you know what rotation direction your pump needs and buy the PTO accordingly.
Can't even use my name
11-03-2004 16:20:25
 Re: Truck Transmission PTO in reply to Red Dave, 11-03-2004 06:28:46
Some pumps are dual input also so rotation of pto doesn't matter. Then again so aren't.
Leland
11-02-2004 18:28:45
Try 1- 800 4parts4 this yard handles a lot of truck parts is a good sized salvage yard in Tower Hill ILL
11-02-2004 18:06:51
You need the numbers off the tranny to get the correct pto. Try this website for good used pto's.
Bob
11-02-2004 16:23:03
The innards of the PTO have to match the individual transmission.
Some truck transmission and driveline shops, or truck body and equipment shops MAY be willing to trade PTO's with you, (for a price) to get what you need.
