Luck with El-Cheapo dress presses?
John in MA
11-13-2000 21:50:58
Has anyone seen these $39 drill presses on eBay? Looks like Harbor Freight-type stuff, but I figure it's not a very expensive mistake. Really looking for personal opinions
Thanks
micheal
11-21-2000 08:41:41
 Re: Luck with El-Cheapo dress presses? in reply to John in MA, 11-13-2000 21:50:58
Hi, I bought one of Harbour freights $39 ones last winter. It is fine for light stuff. I bought mine 'cause i was sick of breaking small bits in my hand drills. I have drilled up to 7/16" holes in 1/2" plate and it has worked fine. tried to drill 5/8" hole in 1/2" plate and that was too much for it. Belt just slipped and could not make any headway. for the <1/2" stuff it is fine. I would not get one off Ebay, though. the shipping on most of them will bring the price to more than a regular harbor freight one. watch Harbor freight and get the $39 one when they have a free shipping coupon.
micheal
Ray
11-20-2000 18:02:34
Bought a 1/2in tabletop, 3/4 hp Ironsmith from TSC stores a few years ago. If I remember, it cost $89. Manual was absolutely impossible -THE ENGLISH WAS UNREADABLE! - If I didn't know about drill presses I would never have gotten it together! After adjusting the lower belt cover so the pulley didn't rub, and tightening the driven pulley so it didn't slip, it has performed flawlessly. Quill shaft has a little more play than I like, but that hasn't been a problem.
john d
11-14-2000 18:59:28
I'm in agreement that $39 isn't a very big gamble these days!
I teach Industrial Technology in a large Indiana Junior High School. If that isn't an atmosphere for potential tool mis-use, I don't know what is! About 15 years ago, I had a chance to pick up two little bench-top drill presses for about $30 each. I got them and the school PTO re-imbursed me. Those things have endured almost daily duty in the hands of 6th-8th grade kids without much trouble.
The return spring for the quill broke on each of them in the first month or so we had them. I eliminated this problem by boring out the center of a pulley to fit on the shaft which raises the quill. Then I installed the recoil starter mechanism from a Sears Eager1 (Tecumseh) engine on the column next to the motor, and ran the cord to the pulley. This provided an efficient and adjustable quill return mechanism. End of that problem.
One of them had a break in the table clamp from being knocked onto the floor (don't ask...) and we solved that problem by installing a small piece of 1/8" steel on top of the broken side, using self-tapping screws to attach it to the broken cast piece. No additional problem there.
I keep waiting for the little motors to burn up, but they haven't. The chucks were 1/2" capacity, and have given no trouble. The handles stay put now, since I added some Loctite to the threads.
We've drilled wood, plastic, aluminum and steel with them. They aren't high-powered, but they weren't high-priced. At $30 each, they've probably cost us less than 1 cent per hour!
big fred
11-14-2000 07:16:19
I have a "Mark I" benchtop drill press I got for about 70 bucks many years ago, I have used it mostly for wood and aluminum, just because that's all I have needed it for. I also find it is a great help when it comes to tapping small holes. Just remove the belt and unhook the quill return spring and it makes a great tapping machine. I would never be able to tap anything smaller than #8 without breaking the tap otherwise.
Fred OH
11-14-2000 06:49:31
My ex bought home one of those el-cheapo drill presses once upon a time. I took it out of the box, admired it and gave it to a brother in law. Then I gave her away. Looked like that it would only be good for a wood shop. If it had a 1/2 hp motor on it, it might drill a 1/2" hole in metal. I have not wanted to use my browser's back button on this deal... L8R----Fred OH
george s
11-14-2000 06:48:55
I have one of the cheap Harbor Freight bench models for years, works fine, but it doesn't get severe use, well at least not all the time:), I couldn't resist the price of Homier's 41/2" angle grinder,but it was a piece of junk, like all things,some of the Chinese tools are much better than others.So the answer is ,who knows, sorry.
JoeK
11-13-2000 23:50:18
I bought a "chinese" 14 spd,5/8 floor model appx 16 yr ago for 99$ and it has served me well for routine tinkering and fabrication.Just have to remember it isn't a real heavy duty rig.I also bought a $39 import benchtop(Homier)a couple years ago,got it home and found quill was bent making it chatter like the dickens,called distributor,who had me send the chuck(only)back and they sent me a new complete press free.It ain't much for power,but it pokes holes OK in light stuff.Would not recommend these cheap units for anything but drilling,ie:no mortising,grinding,sanding etc.Most have inexpensive chuck that will loosen from vibration at high speed/heavy load.(Just my opinion)
