Tool Talk Discussion Forum
Homelite 330 Chainsaw
Jarvy
10-30-2004 13:36:12
I picked up a used homelite 330 chainsaw and need help getting the thing to stay running. The guy who owned it before me couldn't get it started and was turning the high and low screws on the carb, and has it all messed up.
I can get it to start but it won't stay running and was hoping that someone here could give me the default settings on the high low screws and the idle screw settings?
VINTAGE HOMELITE
10-31-2004 15:38:13
 Re: Homelite 330 Chainsaw in reply to Jarvy, 10-30-2004 13:36:12
You might also check the rubber boot/connector under the carb. If this develops a tear it must be replaced (will seem like a carb problem). I have them in stock. $13.95 including shipping.
silvie maybey
11-05-2004 12:51:24
 Re: Homelite 330 Chainsaw in reply to VINTAGE HOMELITE, 10-31-2004 15:38:13
I am looking for a oil pump for our chain saw.
Or does anyone know where to get one.
Van in AR
10-30-2004 15:10:14
About a turn and 1/4 from lightly seated and it should run. If the carb adjustments do no good it may need a carb kit or have a air leak. These saws had a habit of having the main bearings get loose and take the crank seals with them. Check the end play on the crank also, should have no more than about 1/8". Does the saw have good compression?
Van
