Tool Talk Discussion Forum
Cast AluminiumCast Iron
Drifting
10-29-2004 18:29:54
I have an old skeet thrower that has an aluminium arm that is 3.5" wide and varies in thickness from 1/8" to 1/2" thickness. It is broke in a straight line. Also the same machine has a 6.5" diameter x 1" wide gear that has a tooth missing. Could someone tell me the procedure for verifying the materials and the procedure for weld repairs.
Drifting
Drifting
11-01-2004 19:50:44
 Re: Cast AluminiumCast Iron in reply to Drifting, 10-29-2004 18:29:54
I appreciate your comment on the above project. I contacted the manufacture which is Western White Flyer the old machine is electric and they told me to send the arm in and they would weld it. I have some welding experience and would like to try. Thank You
Drifting
T_Bone
11-01-2004 22:21:33
 Re: Cast AluminiumCast Iron in reply to Drifting, 11-01-2004 19:50:44
Hi Drifting,
Well I wasn't going to make a comment as I agreed with Mark, this is a non-repairable item. Why?
"The break sheared in a straight line"
This tells me there's a huge problem, design? Usually when metal shears in a straight line it's from fatique of a design problem.
Repair of this tpye could only cause more problems down the road and most likely injure someone.
T_Bone
Leland
10-31-2004 17:56:48
You can get new ones at most stores for 19.99-40.00 cheaper than an e-room visit and dr bill.
MarkB_MI
10-30-2004 07:22:26
Just so I understand:
You have a device that is intended to throw clay targets a couple hundred feet while you're standing next to it. It's broken in two places and you want to fix it?
No offense, but I suggest you throw it in the trash.
Maybe I'm a little touchy on this subject because of something that happened to me when I was a kid. I was hired one afternoon to load the trap machine at the local gun club. The shooting got pretty fast, and I didn't load a rock quite quick enough. The trap machine went off while the rock was still in my fingers. Fortunately, I was holding it by the top (the right way), and the only thing that happened was I got the beejeezus scared out of me when the rock exploded under my fingers. Since then, I've always had a healthy respect for trap and skeet machines.
