HAND HELD TACHOMETER
JASON
11-13-2000 12:00:29
I RECENTLY PURCHASED A JOHN DEERE #30. IN THE OPERATORS MANUAL IS SHOWS CHECKING SPINDLE SPEEDS WITH A HAND HELD MECHANICAL TACHOMETER. I AM NOT HAVING ANY LUCK FINDING ONE. ANY SUGGESTIONS?
Ray
11-20-2000 18:13:48
 Re: HAND HELD TACHOMETER in reply to JASON, 11-13-2000 12:00:29
Check with a small engine shop, they might loan you one. I have one given to me by a friend - plastic housing about the size of a snuff or chewing tobacco can. Has a dial on the front calibrated in rpm and Hz, and a piece of piano wire sticks out the side. You advance the dial until the wire vibrates at it's maximum amplitude at 1/4 wave, while the case is in contact with the machine, and take the reading. Have checked it against a electronic frequency counter I use for two way radio shop and it's very accurate. Don't have a source of them but someone may..... Can't be too expensive!
T_Bone
11-14-2000 21:57:54
Hi Jason, Try any refrigeration supply house, Johnstones, Grangiers, as there very popular for HVAC. Any tach will work for telling shaft speed as the mechcanial ones do "slip" sometimes if oil is present on the shaft end. I use a digitel one on my VOM as it's much closer and no shaft precleaning required without slipage. These were not available when your book was written.
T_Bone
Bill D
11-14-2000 13:45:16
Jason I found one at Grainger I think they have a web site
Steve from Tn
11-13-2000 12:11:47
If your NAPA doesn't have one, they should be able to order one. If I remember right, they are around $30.
Bayou Dave
11-13-2000 17:17:35
 Re: Re: HAND HELD TACHOMETER in reply to Steve from Tn, 11-13-2000 12:11:47
If you can't get one at NAPA, McMaster Carr, has them, do a search on Tachometer. Grainger probably does as well.
chuck
11-13-2000 19:47:44
 Re: Re: Re: HAND HELD TACHOMETER in reply to Bayou Dave, 11-13-2000 17:17:35
I'll bet they are a lot more than $30 though. I you are near a diesel repair shop, ask them about a photo tach. You might be able to work out some way to have them check your shaft speed for you.
the tractor vet
11-13-2000 20:23:09
 Re: Re: Re: Re: HAND HELD TACHOMETER in reply to chuck, 11-13-2000 19:47:44
Stwart/Warner has just what you are looking for ,I donot have my S/W catolog here at the house ,but find a S/W dealer who sells gauges and have him look in his catolog it is in the back.
