Tool Talk Discussion Forum
Splitting stands
hillbillytn
10-25-2004 14:24:07
Does any one have pictures or information on home built splitting stands that will work for "M" farmall? Thanks!
JerryU
10-27-2004 04:10:49
 Re: Splitting stands in reply to hillbillytn, 10-25-2004 14:24:07
third party image
A gentleman by the name of Marv Baumann who works on Ford 8N's (he actually put a turbine in one!) came up with a devilishly simple idea. You get a crank tongue jack for a trailer (these are available at Tractor Supply or trailer stores for a nominal amount) and bolts it to an angle which in turn he bolts to an appropriate flange on the tractor-you can raise and lower the half to be split, wheel it around and generally do not have a specialty piece of equipment laying around.
FWIW,
JU
hillbillytn
10-26-2004 15:35:33
Thanks to all for the good information I like The idea of Cliff Neubaurer. It looks like you came up with with a good adjustable version for different height tractors. Thanks again
Cliff Neubauer
10-26-2004 15:03:37
third party image
Here is a picture of the set I built several years ago. I used a pair of 2,500 lb capacity side crank implement jacks with a 3,500lb caster wheel mounted to the bottom. I welded 1/2" plate to the tops of the jacks with the proper hole pattern to bolt to the frame rails. We use a 20 ton bottle jack under the clutch housing to support the back of the tractor while it's split. We've used these on everything from our Super H to our 5488 with no problems and they cost less than $200 to build.
Road Warrior
10-25-2004 20:11:03
Here's the link to Kelly C's website. Lots of good pictures and info there.
riverbend
10-25-2004 19:00:54
Kelly C, over on the Farmall and IH board, has made up a set for his 400. I think that he has pictures on his website. Unfortuneately, I don't know the address. Try asking over there.
search me
10-25-2004 17:38:44
do a search on splitting stands lots of info
