Tool Talk Discussion Forum
2 phase electric
fencline
10-16-2004 16:55:30
I did not think there was such a thing but I now have seen a Bridgeport and a Jointer with 2 Phase motors. (on the motor I.D. plate by PH there is the #2) Does anyone know where / why this was used (both 25+ year old machines) Can It be hooked up to two legs of phase converter? The bridgeport I am talking of is hooked to a rotary converter and seems to work OK but seems to start slow.Any information would be appreciated
Thanks,
Andy
brianh
10-17-2004 05:59:45
 Re: 2 phase electric in reply to fencline, 10-16-2004 16:55:30
Check the frequency rating on the motor too. A lot of the two-phase electrical distribution in bigger cities was done at 25 cycles. That might also explain why the motor is big for its size. Brian
Gerald J.
10-16-2004 17:22:56
2 phase makes a fine rotating field for a motor. Most all single phase motors start as two phase motors. The two phases are 90 degrees apart. The phases for three phase are 120 degrees apart.
A T connected transformer on a 3 phase system can get you two phases 90 degrees apart. Basically the connections are: One motor phase is connected line to line. The other phase is connected (with a transformer to correct the voltage) from the mid point of that first line to line connection to the third phase. Called a Scott-T connection.
A three phase motor is probably a little more compact than a two phase motor and should run a bit smoother.
Gerald J.
Bob
10-16-2004 17:14:44
Here's a link to a thread over at Practical Machinest that gives some information on this.
paul
10-17-2004 08:16:09
 Re: 2 phase electric in reply to Bob, 10-16-2004 17:14:44
--->Paul
Bob
10-17-2004 09:09:39
 OOOPS! in reply to paul, 10-17-2004 08:16:09
Link
Link
