Bench top shear for 22-16 guage sheet metal
Shawn
11-07-2000 21:38:54
I scratch build replicas (toys) of farm equipment and have been getting by with cutting 22 guage metal with hand held shears. There are some times when I want to use heavier sheets such as 16 guage. I was wondering if there is a small bench top shear that is reasonably priced.
Thanks,
Shawn
Dave
11-10-2000 07:58:29
 Re: Bench top shear for 22-16 guage sheet metal in reply to Shawn, 11-07-2000 21:38:54
Northern has a mini shear for up to 1mm. Aluminum to 1.5 mm. Cuts and bends up to 7.875". $159.99 in the catalog.
It is a hand lever operated benchtop device. Better control than shears.
Scott Green
11-09-2000 04:57:43
Shawn , I use air operated , hand held , pistol grip shears. I found that the brand name "Devilbis" are the better of the ones I have used so far. $59.00 at Lowes home improvement centers. I make my living with these shears. Not just a home tinker tool. They are good for strait cuts. If you want to cut circles , buy nibblers. Air operated tools are a lot cheaper than electric tools. Of course , you would also need an air compressor and hoses.
T_Bone
11-09-2000 11:40:29
 Re: Re: Bench top shear for 22-16 guage sheet metal in reply to Scott Green, 11-09-2000 04:57:43
Hi Scott, Double cuts will cut a larger arcs or circles pretty fair also. A nibbler doesn't work very well on the lighter gauges and is difficult to cut straigt smooth lines, weighs pretty good some so makes it more difficult to handle for control. Uni-shears are far the best all around. Although a good qualitiy airtool is slightly cheaper in cost than electric, they cost more to operate over a given amount of time.
T_Bone
Scott Green
11-10-2000 04:39:17
 Re: Re: Re: Bench top shear for 22-16 guage sheet metal in reply to T_Bone, 11-09-2000 11:40:29
T Bone , Yes , you are right , double cuts will cut large circles. We are talking about a tool for some one making little hobby tractors. Unless his hobby tractors are a lot bigger than mine would be. As far as cost of the tool goes , I wouldn't pay $250.00 plus for electric shears , when I could buy a good air tool for 1/5 the cost.If the man doesn't have a compressor , he should buy one any ways. As you probably know , the compressor would have many other uses in a shop , besides running air tools.
T_Bone
11-08-2000 00:40:24
Hi Shawn, They make a tool called a Uni-Shear in electric that will do 16ga, around $250 and this slices the SM with you having to apply upward pressure on the piece being cut.
They make double cuts in air $60 don't know how long these will last, or electric Milwaukee $180 that cuts a 1/4" continious slot that curls up as you cut out the 18ga SM and will last forever if used correctly. When you go 16ga is the limiting gauge as you can see. Double cuts will do 16ga but breaks blades really easy if your not careful and blades about $30?, CRS.
There's also a nibbler thats cuts 1/8" wide x 1/4" long nibblets upto 10ga or 1/8" steel and I think those ran about $400 or so.
Double cuts are by far the best way to go and Milwaukee is the best. So if you do alot, I would consider this option first. Do you really need 16ga or could you get by with 18ga?
There is also a hand orperated floor mounted uni-shear that works the same as the electric ones and varies in capicity upto 14ga?(CRS)and is guessing $500. You can do some very nice work with this machine tho.
If you need more info let me know and I'll see if I can find you a page on the net too look at.
You do have a pair of Weiss hand bull-dogs don't you? There also good for 16ga but your hands will know it when you get done!!!
T_Bone
Shawn
11-08-2000 15:45:50
 Re: Re: Bench top shear for 22-16 guage sheet metal in reply to T_Bone, 11-08-2000 00:40:24
T-bone,
I could probably get by with using 18 guage. Does the uni-shear leave a nice straight, almost factory type edge, or do you get some curling on your cut piece? I would be interested in a website if you know of one. Right now I've got acouple different type of hand shears. I don't recall what make they are, just that you definately feel it after cutting awhile.
Thanks for your suggestions.
Shawn
T_Bone
11-08-2000 17:18:08
 Re: Re: Re: Bench top shear for 22-16 guage sheet metal in reply to Shawn, 11-08-2000 15:45:50
Hi Shawn, The uni-shear doesn't leave curlings on either piece cut. It takes some geting used too using as it cuts just like a pair of hand snips. The closer you keep the blade adjusted the smoother the cut. Brand wise I'm having trouble remembering. I do remember there's not much choice of brands as two I think made them and both were excellant. Getting used to the way they cut, you have to lift the leftside cut piece and is not really a problem until you cut about 4ft into a sheet then only skill of use will have to kickin. also it has to be balanced correct from forward pressure to rear pressure. It feels natural to let the back of the uni-shear hang down but it will stop cutting until your balance is correct and thats the skill I'm talking about. It'll be awhile before I can take the time to find a website for you, but I will.
T_Bone
F14
11-09-2000 04:09:42
 Re: Re: Re: Re: Bench top shear for 22-16 guage sheet metal in reply to T_Bone, 11-08-2000 17:18:08
I've used a Kett electric shear to cut 16 gauge. Cut 4" off the long side of an 8' piece. That was a tad too wide, so I cut a shear width (about a quarter-inch) off.
16 gauge was a handful for the shear, but it did a nice job.
