Tool Talk Discussion Forum
OT 01 Ford F-250 Diesel engine coolant
Dave F.
10-12-2004 09:06:13
I am considering to purchase an 2001 Ford F250 diesel. with around 77,000 miles, a while back on this forum there was something about the engine coolant that should be checked? also anything eles(sp) I should know & look at. This is going to be my first diesel. it has an atomatic transmission. Thanks Dave F.
mud
10-13-2004 14:03:00
 Re: OT 01 Ford F-250 Diesel engine coolant in reply to Dave F., 10-12-2004 09:06:13
hi- i just went through this with a 2000 f-350.
napa was the only store for miles that stocked the zerex gold. drained out the old and water flushed it. runs the same but i sleep better.
Red Raider
10-13-2004 10:26:11
If the truck has green coolant, replace it with that, if gold then use that. It is CRITICAL to use the FW-16/ DCA-4 engine coolant additive. Levels should be checked with test strips available from your local International Truck & Engine Corp. dealer. If the additive is not used, pinholes will develop in the water jacket around the cylinders (terminal end).
Leland
10-12-2004 11:08:16
Dex cool will work just fine be sure you flush old out first .
