Tool Talk Discussion Forum
JD quad range tool
agri_con
10-11-2004 04:54:33
Anyone have any ideas on an alternate tool for the sychro's.Short of buying one or fabricating one out of steel.any other ideas.Was wondering if tapering down some PVC pipe would work.The tool I'm talking about is the one to keep the balls and springs in place on the low/high collar on top shaft.
Bob
10-11-2004 06:42:28
 Re: JD quad range tool in reply to agri_con, 10-11-2004 04:54:33
Some wheel bearing grease on the balls and springs to keep them from flying quite as far, as you're "learning", and some nimble fingers are all that is needed. I've done two in the past month, with no more equipment than that!
