Well, I just got finished replacing the rotten fuel hose on my 2800 forester and it runs so much better! My 2800 appears to be nearly identical in construction and layout to your 3400. It had two fuel hoses going into the tank. The aft hose extended inside and had the filter on it and was the "flop" hose, it went to the inlet on the LH (choke knob side) of the carb. The forward hose from the tank, the larger hole had a hose pass thru it and had a funny little one way check/vent valve on it. You pull the hose thru and out the filler neck, put the check valve on the hose, which expands it, and pull the hose back up into the hole, while pushing on the valve/vent with a finger sticking thru the filler opening. When properly pushed up in the hole the slightly expanded hose seals tite in the larger hole. the hose runs up the LH side of the carb past the gas inlet and over the top and down the right side where it ends. It is merely a tank vent. There is a third hose, runs from a fitting on the crankcase and goes to the RH side of the carb, opposite the inlet hose. It is some kind of pump pulse or balance hose. Was rotten and broken on mine and it didn't run well without it, but great after I replaced all three hoses. I went to the Poulan web site and looked for manuals for your 3400, the search didn't turn up anything. Its a goofy web site, won't give you a list of manuals that are available, but rather makes you input the model and returns with the "none found" leaving you wondering what you could do differently to locate the manual. Not too friendly. Go to Link And select "Illustrated parts diagrams online" and then when the new window opens expand the window to full screen and then click on the "click here for parts lookup" and using the "catalogs" drop down box in the upper left, select Poulan/Weedwater... then Poulan.... then Gas.... then Saw... then select your model saw. There are several drawings and a complete parts list. This is great. They have this electronic parts manual for a whole bunch of differnt brands of saws, trimmers, mowers, etc. Hope this helps, Charles
