Tool Talk Discussion Forum
DOUBLE TROUBLE NEED HELP FAST
Andrew
10-07-2004 14:24:53
got a small job on the side hear refinishign tables well i sanded one down rigth to bare wood liek you should then i stained it i used varathane 309 dark walnut thats what they want... WELL IT NEVER SOKED IN and it looked liek 2 week old dog sh*t with a faint snot green look not happy NOW these tabels are made out of oak witch is hard to get stain into but i have doen lots of oak and it goes in fine. there 3 inches thick with a rounded edge. i have no clue what to do now i guess i owe them a new table because of this stain that wrecks most everything... I have done lots of oak with stains but this isnt stain and tips on what i shodul do would be great need help fast!!!!!
Nolan
10-08-2004 03:37:47
 Re: DOUBLE TROUBLE NEED HELP FAST in reply to Andrew, 10-07-2004 14:24:53
Wipe them down and clean them up. Then, use a dye, not a stain. Stains never do go deeply into the wood, a dye will. Well, at least deeper then a stain will.
Bus Driver
10-07-2004 17:16:15
The stain instructions usually say to let the stain soak in for a few minutes- maybe 15?- and then to wipe off the excess. That procedure insures that stain does not remain puddled on the surface. Gel stains are easier to get an even color because the darker places can be rubbed harder to remove more stain. BE SURE to read and follow the directions.
Kendall
10-07-2004 14:42:57
What about a pre-stain wood treatment product?
Vern-MI
10-07-2004 14:38:48
Raise the grain using steam or hot water on a cloth. That will open the pores and allow the stain to take. After raising the grain allow it to dry for a few days in a warm dry place before applying the stain.
Andrew
10-07-2004 15:58:24
 Re: DOUBLE TROUBLE NEED HELP FAST in reply to Vern-MI, 10-07-2004 14:38:48
ill try this its pretty cold hear now like +1 or 2 and i dont have to much time to do one table i only have 4 days thisis my 2nd and it will take teo days to do varnishing. how do i take the stain that i put on off solvant???
Andrew
10-07-2004 16:34:18
 Re: DOUBLE TROUBLE NEED HELP FAST in reply to Andrew, 10-07-2004 15:58:24
im going to try some minwax my friend got me some and she soaked rigth in and its the prefect color.... wounder what is up with that varathane
txblu
10-08-2004 06:29:03
 Re: DOUBLE TROUBLE NEED HELP FAST in reply to Andrew, 10-07-2004 16:34:18
Is it a "varnish or polyurethane" stain?. These have stain and finish coat. Molecules are thick (to support the finish coat part) and do not go easily into the pores of a hardwood like oak.
Gotta use pure stain and then come back with your sealer coats.
Opinion: If you did use varnish, you sealed the pores. To get the real stain to be absorbed into the grain, you need to get the varnish off and out and that might requiring sanding thru the level where it was, to new wood.
Mark
ebbsspeed
10-07-2004 16:46:03
Is one water-based and one oil-based? Some of the water-based stains will look a big blotchy if the wood was previously finished with an oil-based stain or sealer. I"ve never liked to use the water-based stuff on anything but raw wood that was being finished for the first time.
Andrew
10-09-2004 21:01:20
 Re: DOUBLE TROUBLE NEED HELP FAST in reply to ebbsspeed, 10-07-2004 16:46:03
I fixed my problem: i got this paint striper called Home Strip i put that on wiped it off in 30 min THEN. i ran to the CO-OP they mixed me some stain up and put a coat of pre stain on it looks real good no splotchy nice even coat Thanks guys...
