Tool Talk Discussion Forum
how can i cut tyres?
katcha
10-07-2004 11:49:54
i sculpt with old tyres, but keep goin through a lot of blades on my jigsaw. to cut the sides i use a flat blade. to cut across the tyre where the metal is is the biggest problem.. lots of broken blades. i tried with the angle grinder but that melts it! any ideas?
GM Tech
10-08-2004 11:00:38
 Re: how can i cut tyres? in reply to katcha, 10-07-2004 11:49:54
Sawzall with a steak knife modified to fit, Git R Done
Fepo
10-08-2004 08:25:27
angle grinder with very thin metal cutting fiber disc should do the trick. Disc is like 1/16 thick so should have minimal melting.
Nolan
10-08-2004 03:35:51
Wonder how that new double bladed saw from Sears would do on it. Might do a dandy job.
Bus Driver
10-07-2004 17:26:18
Both the wires in the bead and the belt on radial tires are very hard steel. The belt wires are very fine and if a blade will cut them, the finer tooth blade is the better choice.
Kendall
10-07-2004 14:45:04
Try a sawzall with bi-metal blade.
sawz-all?
10-07-2004 13:05:02
use a hack saw blade with one (bi-metal)
