Tool Talk Discussion Forum
Check ebay for chainsaws/parts
Heads Up
10-07-2004 07:12:47
Not promoting,but when you can buy a name brand factory refurbished saw w/warranty for less than the cost of a tank of gas for your pickup..... !
lucas boy
10-08-2004 19:39:00
 Re: Check ebay for chainsaws/parts in reply to Heads Up, 10-07-2004 07:12:47
you an realy get some good buys on ebay but you can also get burnt. if you use your credit card you can do a chargeback if you get burnt.. lucas
rustyfarmall
10-07-2004 12:07:32
You want to be a little cautious with so-called "refurbished" items. You may get lucky because there was nothing wrong with it in the first place, or you may find that it had a major problem from the factory and still has that problem. As in everything, if it's cheaper, there usually is a reason.
