Tool Talk Discussion Forum
Will the Sweats Hold?
Joe MD
10-04-2004 14:22:47
In a bathroom remodeling attempt I've found myself sweating my first copper pipes. I had to make about 12 connections from ball valves to diverter to shower head etc. etc.
Being my first, they look ugly, but seem solid.
Will they leak? They're holding water now.
The pipes will be behind a tiled shower wall so it would really stink if they started leaking mid-winter.
I never welded or anything before so perhaps I'm lacking in confidence.
rhouston
10-05-2004 08:37:54
 Re: Will the Sweats Hold? in reply to Joe MD, 10-04-2004 14:22:47
all very good advice. The only thing I would like to add is don't get too much soldier in the joint either, it biulds up inside the pipe and can cause noise.
lucas boy
10-05-2004 05:59:35
if you wipe the joint with a rag while its still hot it will look professional and corrode less..lucas boy
Vern-MI
10-05-2004 05:28:09
If you are in doubt try one on the bench and then take it apart afterwards to see if you have complete solder coverage of both fittings. What products did you use in the process? I prefer Oatey products to others I have tried.
George G
10-05-2004 02:51:51
When I started work at the place that I'm at now. They had a guy their, he showed me how he soldered joints. He would hold the torch up to the joint and at the same time hold the solder up to the joint. Melt the solder around the end of the joint, he was done. The first five years I was their, I repaired a lot of water leaks, most of them were joints that had solder around the end of the fitting, no solder trawn into the fitting. Kinda tells me that a solder job not done right, could last for a while, time will tell.
Larry in Tn
10-05-2004 05:47:12
 Re: Will the Sweats Hold? in reply to George G, 10-05-2004 02:51:51
George made a important point. The solder has to get in the joint if it's going to really hold. Clean the joints with a steel brush or steel wool and apply the fluxing agent. I like the paste type in the round can. Join the pieces by hand and apply heat to the female(???)outer surface of the joint but not directly at the joint junction. When joint gets hot enough to melt solder at junction apply same. Capulary(sic?)action will draw the solder into the joint. Heating the solder directly makes a "cold" joint because the copper is not hot enough for the solder to bond to it. A good joint will not have solder dripping off it. Proper heating will let the solder fill the entire area of the joint.
Larry
Davis In SC
10-04-2004 17:35:26
It is my experience that the flux left next to the soldered joint is the cause of leaks, where it corrodes the pipes. Ever notice all that green corrosion there? I feel it is worth the time to clean & neutralize the flux after soldering. A minute with a wet rag & some baking soda is all it takes... Regards, Davis
LumbrJakMan
10-04-2004 17:08:44
Heres a neat trick for you to try . get a few different size Fitting cleaner wire brushes ,1/2" 3/4" 1" . They are about a buck or two. Cut the twisted wire right near the handle . Throw the handle in the wood stove. Now just stick the end in your cordless drill and tighten the chuck . use some gloves to hold your fitting , and send it in the fitting and pull the trigger . You can save a lot of wrist twisting , and its works very fast !!!
george md
10-04-2004 16:21:12
Joe, I don't know what part of md you are in , but
where I am you do not put copper any where you
can't see it and get in to repair or replace . Put in the best grade of plastic pipe you can
get . Around here copper only lasts 5 or 6
years .
george md
Mark - IN.
10-04-2004 16:54:28
 Re: Will the Sweats Hold? in reply to george md, 10-04-2004 16:21:12
If they haven't gone under pressure by now, may and probably are good. Outside doesn't mean a hill of beans, unless astetics (good looks) are your concern. When you sweat, you want the solder to get sucked/drawn up into the joint to fill and hold the two pieces together, not just what you can see visably at/on the outside of the pipe.
Best flux for sweating pipes I've ever used I found at Menards by accident in a pinch. Can't remember the name, but is clear liquid form, and comes in a clear squeeze bottle, like 6 or 8 oz. You'll find it by their solder. I scuffed the insides and outsides of all my fittings and pipes with emery cloth, put them together and heated, then squirted on some of that flux. The solder got sucked/drawn in as fast as I could feed it. When I looked inside my joints, all had a nice bead around the edge of the pipe (inside the fitting).
I can't remember the name of the stuff, and am no fan of Menards (too much Chinese for me), but that's great flux, the best I've run into yet.
Darrell wilson
10-04-2004 15:22:56
Any way to cap off one end and put a air test on it we always put 1 and a half times the working pressure to test but if she aint leaking now you are good i would say the key to sweating copper is make sure youclean the pipe and fittings well with sand paper and a fitting brush good flux and dont get it to hot my 2 cents Darrell the plumber
MAC,IL
10-04-2004 14:34:50
Takes practice to make a good looking solder joint. I seen some beautiful solder joints leak like the devil. If they dont leak now, I wouldnt worry about them.
mud
10-04-2004 14:34:07
you done good. now close her up
mud
Peanut
10-04-2004 14:30:33
You are lacking confindence. If you have pressured water in the pipes now and you don't see a leak, you are good to go. Close up your wall and grab a frosty bottle of beer. There are no home remodeling awards for pretty solder jobs.
In the future, look for the copper fittings that are pre-soldered. They are SO MUCH easier than messing with the strand of solder. Just flux, heat, and seat. They don't cost but a few cents more than the normal fittings.
Larry E
10-04-2004 19:23:59
 Re: Will the Sweats Hold? in reply to Peanut, 10-04-2004 14:30:33
Solder paste is best,solder will not stick to un fluxed fittings.So you are controling what your solder job looks like.It takes 1''of solder to do a 1''od pipe ,2'' for 2''and this is true for all sizes.Clean parts is the secret to a good job.Also solder will go up vertical 11''.You do not have to solder down or horizontal.
Big Jim
10-04-2004 20:08:00
 Re: Will the Sweats Hold? in reply to Larry E, 10-04-2004 19:23:59
My favorite for plumbing these days is a paste that has both solder and flux in it. Clean up the cooper reaaly well, paint some of this stuff on, slip the 2 parts together and heat. I usually only need to add just a little bit of extra solder. I did a couple of dozen joints in a retrofit project a couple of years ago and didn't have 1 leaker. Not bad for a guy that does not claim to be much of a plumber.
