U-joint-(oops)
Ron
11-04-2000 14:19:33
I put two new u-joints on the drive shaft of my 89 GMC pickup. I took the shaft two work and put them on there since I had access to a big vise, so I didn't have the truck handy. I was thinking that I should put the grease fittings to the inside towards the shaft on both ends. Putting the shaft on I realized that I should have put them oppusite meaning facing out. I can get to the one on the transmission side although it's tight but on the rearend side I will have to use a needle connection on my gease gun to grease it. Should I go to the trouble of taking it all off again or will it be O.K. to just leave it like it is?
Thanks for you input.
BlueLight
11-05-2000 11:11:17
 Re: U-joint-(oops) in reply to Ron, 11-04-2000 14:19:33
Nahh, leave it the way it is. With the needle
fittings just don't let it get too dry. You don't
have the grab of the nipple on a dry joint, and
with the needle if the hole rusts over you've
had it..
H MN
11-04-2000 14:30:02
Ron: ..and here I thought I was the only one to have done that. I just let it be and set one grease gun aside just to do that. As long as I can get grease into it, I let it stay that way. harvey
Ron
11-05-2000 11:19:42
 Re: Re: U-joint-(oops) in reply to H MN, 11-04-2000 14:30:02
Yea, I think thats the best thing to do. It doesn't look like it will a problem rubbing on anything so I'll just get a adaptor for my grease gun and leave it be. Thanks for the advice. Ron
