Tool Talk Discussion Forum
Soft Crescent Wrench Jaws
Jim-PA
10-02-2004 07:13:35
A friend gave me a 24 inch Crescent wrench. It was made by Crescent and not an import. The problem is the jaws are soft and the metal destorts when you try to use it. Is there any way to harden the jaws so the wrench can be used or do I just have hammer shaped like a wrench.
Coloken
10-02-2004 09:03:12
 Re: Soft Crescent Wrench Jaws in reply to Jim-PA, 10-02-2004 07:13:35
It it is a real Crescent I think some thing is wrong and they will replace it.
kraigWY
10-02-2004 07:24:17
You can harden the jaws but why, my father would beat my tail every time he saw me go after a bolt or nut with a cresent wrench, find the proper wrench for the nut or bolt. Cresent wrenchs are fine for soft brass, propane bottle cupplings and such, you dont need harden jaws for that. But if you want to harden them, heat the jaws untit they reach critical temp (no longer magnetic) quench in oil, draw the temp out in a lead pot, say 450 degrees for about 20 min.
K
skeeter
11-17-2004 18:46:55
 Re: crescent wrench in reply to kraigWY, 10-02-2004 07:24:17
How do I take a crescent wrench apart to get the screw out of it?
