Tool Talk Discussion Forum
Welding Helmets (Sorry, This is NOT Off-Topic)
OK-AL
09-30-2004 19:38:48
It seems like there's a million off-topic questions on the boards now, so I thought that i'd put a on-topic question out there. So here it is: Which brand of auto-darkening welding helmet do you guys that weld for a living use?
The reason that i'm asking is that i'm changing careers. Going to school to learn welding. I only want to buy one helmet and I want it to be a good one that I can use at work. I'm more worried about eye protection than just about anything else.
Thanks in advance for any opinions.
OK-AL
Scott V
10-03-2004 18:31:52
 Re: Welding Helmets (Sorry, This is NOT Off-Topic) in reply to OK-AL, 09-30-2004 19:38:48
As a fan of the top Speedglas helmets, I will say get a Optrel Satellite. They are wonderful and very solid.
OK-AL
10-01-2004 18:07:04
 Re: Welding Helmets THANKS FOR THE REPLYS! in reply to OK-AL, 09-30-2004 19:38:48
Thanks to everyone who ansered my post. Some good things that I never thought of. That's what is great about this board - lots of good folks and experience here!
I'll let you know what I end up getting. (Waiting for welding school to start - can hardly wait to get started!!!)
OK-AL
T_Bone
10-01-2004 21:39:13
 Re: Welding Helmets THANKS FOR THE REPLYS! in reply to OK-AL, 10-01-2004 18:07:04
Hi Al,
Here's one of my previous posts on my welding hood thoughts:
The most important part of a welding hood is the lens as it protects your eyes. Welding is very hard on your eyesight. I went from a minus 125 vision correction to minus 575 (coke bottles) in 20yrs of full time welding. I then backed off of full time welding(8hrs/day) to 8hrs/week for the next 10yrs then to couple welds a year for the next 10yrs and my vision in the past 10yrs has returned to minus 450. Not good but showing just how welding can effect your eyes.
There is a difference in a plastic lens and a all glass lens. A plastic lens will create a weld puddle distortion of two weld puddles with-in the lens area. One phoney weld puddle and the real weld puddle. This distortion can be seen best seen while Tig welding but is present under all types of welding. A all glass lens will stop the distortion. The best glass lens I found is called a Cool-Ray lens. The glass cool-ray lens has a layer of gold over the glass face. They cost about $60 eh but well worth it as your eyes will not be tired nor burned at the end of 8hrs of welding. Being there is a layer of gold on the outside of the lens, you want to use a fiber gasket, then a clear glass lens, then the glass cool-ray lens, then another clear glass lens on the inside. There is a gold colored plastic lens, this is not the correct lens!
Plastic corrective eye glasses will also give the weld puddle distrotion.
How can you tell if your eyes have been burned or your feeling the effects of welding? At night just before you fall asleep with your eyes closed you will feel a very warm feeling in your eyes. This is welding burn also called flash burn. Your eyes are telling you to do someting different!
Welding shade number:
I found over the years that a number 10 cool-ray is good for stick and Mig welding and a number 12 is good for Tig welding.
The best welding hood I've found is the Huntsman 411P. It's made from a lite weight fiber thats easy on the neck and cool on your face after 8hrs of welding. Plastic or fiberglass hoods will heat soak while welding where as the fiber hood will not heat soak. This will cause you to become tired easy thus letting your eyes wonder and not consentrating on the weld puddle.
Autodarkening welding hoods:
I'm not a fan of the auto hoods. One, they use a plastic lens and you get weld puddle distortion. Two, there heavy and your neck will let you know it at the end of the day. Three and the big one, what comes first to make the autodarken feature work? The ARC strike! so your eyes will pick-up a small amount of arc flash before the lens darkens.
So how do you tell where to stike the arc? Place your electrode next to where you going to strike the arc then flip down your hood, then strike the arc. With experience you will quickly master striking the arc where you want it.
T_Bone
Davis In SC
10-02-2004 21:49:07
 Re: Welding Helmets THANKS FOR THE REPLYS! in reply to T_Bone, 10-01-2004 21:39:13
T_Bone, glad you spoke up on this subject... I do not do much welding anymore, but I hear everyone rave about Auto helmets. Frankly , they scare me... I have wondered if years down the road, bad effects to weldor's eyes are going to be found ??? If I were going to buy one, I would do lots of research, & not spare any expense, because I only have one set of eyes !!! I would be very hesitant to use a Harbor Freight Special..... . Regards, Davis
BillWV
10-02-2004 20:35:39
One of my welding books agrees about the auto-darkening lenses.
I know they are all the rage, and I don't know since I'm not a commercial welder - never welded more than a couple of hours a day. But the book claims that for somebody that is striking a lot of arcs durning the day, those millisecond delays in the darkening add up, and mean "sandy" eyes by the end of the day.
Bill
David - OR
10-01-2004 07:36:42
Go down to the local welding supply shop and find out for which brands of helmet they carry replacement plastic shields. It will probably be Speedglas and maybe one or two others.
Since these shields are, in effect, consumables, it is handy to be able to buy them locally instead of ordering in bulk from China or wherever.
TimV
10-01-2004 06:14:18
OK-AL: I don't weld professionally, but most of my friends that do use either Huntsman or Speedglas. I agree with you--it's better to buy one good helmet and be done with it. Safety gear is nothing to trust to people who buy from the lowest bidder. You only get one set of eyeballs per customer, and I'd still like to be using mine when I'm 90.
Pile Buck
10-01-2004 04:28:57
Hi OK-AL. One thing I can suggest to you, if you are about to join the ranks of welding for a living. It might be hard to do so right now, but try to imagine where you see your self in the next few years. I mean working in a fab shop, manufacturing a product, construction, shipyard, or the government. My point being with profits being down for the owners of any of theses places, except the government no body is going to want to replace a $300.00 welding helmet when broken or stolen. If you had showed up to work for me with a helmet like that, I would have let you known instantly to put it back in the car and to use the companies. When I welded for a living I probably went through two welding helmet a year. Either dropped them in the bay, on the ground, or someone else helped me out here! Now someone may be thinking the union will require the company to replace your helmet. Think again, I never worked nonunion. Every union I ever worked around required the company to supply safety equipment, but not to replace every little toy someone decided to use on the job. Just a thought!
Big Jim
10-01-2004 02:28:59
I would buy one of the cheapies to start out with and use it a little while. That way, when you are ready to lay out $300 for a good one, you will have a feel for what you like and dislike about helmets. I'd hate to buy a hi dollar one and then discover the suspenion eats a hole in the back of my head or something like that.
Ben in KY
09-30-2004 22:21:26
Not trying to put you off, but if you are going into welding here is a good site. Also T_Bone will hopefully chip in and give you some good advice on the helmet. I have an el cheapo harbor freight one that works for me, but I would get a better one if I welded for a living.
