Tool Talk Discussion Forum
Toilet question.
James in North
09-30-2004 17:46:51
OK, here goes. In our building, one of the wall urinals is not working properly. Sometimes, when you push down the flush handle, it will pop back into place but the water continues to run. I have to jiggle the handle a few times to make the water stop. Any ideas on the most likely culprit? Thanks James
greenengr
10-01-2004 18:08:45
 Re: Toilet question. in reply to James in North Carolina, 09-30-2004 17:46:51
I also wanted to add that if the pressure gets too low in the water line, this will open the sloan valves. So just as a check you may want to make sure your water pressure is sufficient (e.g., < 30 psi)
di-dah-dah-dah
10-01-2004 03:11:35
James, while you're at it, put the cap back on, without the guts, open the valve and give it a quick flush to clear out any scale that may be in the pipe. Then proceed with the task at hand.
Good luck
RT
09-30-2004 22:37:57
James, you need a new vacuum breaker in the valve. Its probably a Sloan. Just get the kit it will come complete.Make darn sure you turn of the water.There should be a turn off to the left. It might be under a cap, but general rule it will be on the left. Turn the screw in then flush the urinal to make sure the valve turned the water off. Watch how it comes apart and put it back together in that order. Hope this helps, RT
buickanddeere
10-01-2004 08:12:40
 Re: Toilet question. in reply to RT, 09-30-2004 22:37:57
Funny you should mention shutting off the water. The hot water cartridge in the Moen brand sink taps began to leak. I shut the hot line off and sent the wife to town for a replacement. I opened the bag and found two valves cartridges. The clerk sent two free replacements as the cold may as well be replaced at the same time. I changed the hot cartridge but part way into the cold replacement something became ovious. The cold water hitting the ceiling was a late reminder to isolate the cold supply as well.
Kendall
09-30-2004 20:31:58
I rebuilt one of those one time. It just needs new guts. Take it apart, take the parts to a plumbing supply store so they can see what you need. Easy to do.
Bayou Dave
09-30-2004 19:56:33
Local plumbing supply house will have a rebuild kit for it. Tell them the name on the valve. Usually costs around $35.00 or so, and your good to go...(pun intended)
Engineer20
09-30-2004 18:45:46
James,
Open the top of the valve. (where the flush handle goes in) You can mess with it or just replace it.
Mike
ChrisH (IA)
10-01-2004 07:05:35
 Re: Toilet question. in reply to Engineer20, 09-30-2004 18:45:46
You may have the volume screw (under cap) turned down too much. Our urinal did the same thing and would flood the floor cause the drain (p-trap) was nearly clogged. Put in a new trap, increased the volume and the problem was solved. This was AFTER the valve was rebuilt.
