Tool Talk Discussion Forum
well
cas
09-30-2004 04:53:26
Why cant i find a Fu Sheng like it on the web??
Later cas
Roger P.
10-01-2004 14:00:18
 Re: well in reply to cas, 09-30-2004 04:53:26
It's an older model Fu Sheng, about 1 model behind the current ones. Eagle makes compressors with the same pump. How do I know it is a Fu Sheng? Because a few years ago I had an Eagle PT-03 pump with two bad rods and pistons. I also had a Fu Sheng D-4 pump in pieces. The rods, pistons and rings were identical, even though the D-4 was a newer style pump, or at least, a different style pump to differentiate it from whatever they are selling to other manufacturers. I rebuit a Fu Sheng VA-80, and it had the exact same squared-off crankcase as yours. The equivalent pump for an Eagle would have been a PV-05.
buickanddeere
09-30-2004 05:52:29
They cloned the Honda motor too but probably forgot to pay the royalties on it as well.
Big Jim
10-01-2004 02:42:59
 Re: well in reply to buickanddeere, 09-30-2004 05:52:29
The Chineese are masters at duplicating the look of good stuff with slightly inferior materials and tolerances. Can't tell it from the high dollar brands except it doesn't last.
Mark - IN.
09-30-2004 19:47:04
 Clone in reply to buickanddeere, 09-30-2004 05:52:29
Sure is yellow.
