Tool Talk Discussion Forum
Piloted Drift
Phil from Maryl
09-28-2004 12:45:48
I know what a drift punch is and have several. What is meant by piloted drift? I have seen this term used many times and never really understood what is meant by piloted?
Thanks
Phil
Ben in KY
09-29-2004 08:50:58
 Re: Piloted Drift in reply to Phil from Maryland, 09-28-2004 12:45:48
One version of the piloted drill bit is used for sheet metal and such, less walking around when starting the hole.
Davis In SC
09-28-2004 15:13:47
It has a smaller Diameter on the end to center it in a hole. Used for things like punching out a bushing.....
Stickler
09-28-2004 14:21:54
piloted drift is a drift that has another step in it so the pilot or smaller diameter part can fit down inside something and not be able to slip out of place when it's pounded or pressed.
tech4
09-28-2004 13:21:12
I think that is when a drift punch is used in a hydrolic press to press a pin or whatever out instead of by hand and a hammer. The press is piloted straight.
