Tool Talk Discussion Forum
Hey T_Bone need welding info
Keith-OR
09-27-2004 21:10:27
T_Bone, need some advice on what rod to use I haven't run a stick welder in 25 years, What I have is 7024, 6013, 6011 and 7018 need to know which would be the best for welding up 5/16 steel I am using to make a light front loader bucket. What I know is that 7024 seems to be a horizonal rod. All your help would be greatly appreciated.....Thanks
Keith
T_Bone
09-27-2004 22:08:24
 Re: Hey T_Bone need welding info in reply to Keith-OR, 09-27-2004 21:10:27
Hi Keith,
7018 would work just fine. For flat/horizonal work the 7024(also called jet rod) would also work well.
What you might consider doing is running some test beads with 7018 on a "T" joint fillet on one side, then let cool, then break the weld. Besure that the weld breaks down the center or mostly down the center, if not then practice some more until they do.
T_Bone
Keith-OR
09-27-2004 23:23:22
 Re: Hey T_Bone need welding info in reply to T_Bone, 09-27-2004 22:08:24
Thanks for the advice, will work on this in the next couple of days. Have a little one that has a birthday tomorrow, so won't get much done. I have a MIG welder but brought the stick arc welder out of moth balls to do this job.
Thanks again T_Bone.
Keith
