Tool Talk Discussion Forum
Small concrete pour for drainage
ShepFL
09-27-2004 13:16:39
third party image
Howdy fellas -
Got thru this last hurricane pretty much unscathed. Pls send prayers and well wishes to those that got slammed. Central and South FL.
Dec. 2003 we moved into our newly built home. With the recent hurricanes I see some minor modifications are needed. When slab was poured it was level to build on. Porch areas were also level.
Wanting to add some sloping concrete so hurricane rains (blown in) will run away from house. Right now the water just stands till I sweep it off.
What is the best way to pour some concrete over existing slab with a gradual slope to force water to run off the porches. On porch is floor level and other is 2nd story balcony with light weight concrete. This is pic during construction. No recent photos to share.
Thanks, ready to learn.
ShepFL
1945 A
09-28-2004 15:19:13
 Re: Small concrete pour for drainage in reply to ShepFL, 09-27-2004 13:16:39
It's hard to tell from the view shown, but, you could possibly add a slope to the top of your existing slab, from just below the thresh hold to the edge. There's grouts out there that will not shrink, have substantive strengths, and will finish out to a feather edge. You might also get away with buying a masonry blade, and cutting some rain/water channels in the slab, but that might not look as good. If you have enough thresh hold height, you could also put tile, and incorporate a slope when doing so....
Just some thoughts. Glad you survived the hurricane, and good luck with whatever you decide to do!
ShepFL
09-29-2004 08:18:30
 Re: Small concrete pour for drainage in reply to 1945 A, 09-28-2004 15:19:13
I like the idea of tile at an angle. Wife loves the idea of tile. I got some left over from the construction. Will run with that.
Threshold height is approx 4" (1 brick plus mortar) to slab.
1945 A
09-30-2004 07:23:18
 Re: Small concrete pour for drainage in reply to ShepFL, 09-29-2004 08:18:30
Tile will make a good looking addition, I think, and it"s something you can do yourself, if you"re so inclined. I ripped carpet off a bathroom floor a few years back, and replaced with tile. It was really a pretty straight forward job, and looks pretty good.
One thing I would suggest, is get the best grout sealer you can find, and seal the grout, (so it won"t stain from water, leaves, etc.) There is some maintenance with a tile floor, but again, it"s not hard to keep up.
Good Luck!
Leland
09-28-2004 06:23:27
Shep is the crete bonded to foundation, it not you may be able to get somebody to pump grout under back of porch to raise it about an inch or two. we have companys in my area that level or raise concrete all the time. a lot cheaper than a complete tearout just a thought. GOOD LUCK that a mighty fine looking snack you have built fer yerself there. and some what hurricane proof to by the look of it.
Mark - IN.
09-27-2004 16:07:16
Hey Shep, glad to hear that you and yours are OK. 4 Hurricanes and major storms like that? Not me buddy. I'd prefer the occasional nearby tornado, that way I can just keep runnin' around the property in one huge continuous circle and let it pass by me as I duck and weave. Tornados stink, but I aint ever seen one as wide as the state of Florida is long. Biggest I've seen was about a mile in diameter.
As far as concrete goes, I think that if I were you, I'd talk to a concrete barber, and let him make suggestions. Seems to me that a thin layer of concrete would crack to pieces in time, unless was re-inforced with rebar, fiberglass webbing, or something. I could never get away with that where gets 90 degrees in the summer and sub-zero in the winter. Would be a cracked up gonner in no time. Let a concrete guy take a look at. Maybe needs to be cut or shaved down before can put a layer on thick enough to get your money's worth.
The kicker in all of this is that the concrete guy could've and should've put a pitch away from the house to begin with, in my mind. But then again, what do I know - might get wet and someone slips and falls because of the pitch, and...
Call the concrete guy, he oughta know best. By the way, nice looking house. Got a tornado shelter? Ha Ha Ha Ha. I oughta get one of those - that runnin' around in a circle is gettin' to my knees and has the neighbors laughin' behind my back.
