Tool Talk Discussion Forum
Square head bolts and nuts!
JD790
09-25-2004 21:47:42
Why were they so popular many years ago?
Was it because they had a lack of pnuematics and relied on wrences!
They must of had special machines on the belt line that dealt with these fasteners while building old farmalls and such.
Wonder when the first 6 sided bolt was manufactured?
tech4
09-27-2004 09:58:05
 Re: Square head bolts and nuts! in reply to JD790, 09-25-2004 21:47:42
The first bolts were square head and cut to common dimensions that would fit wrenches. The square head bolts were in the open where you could place a wrench from almost any angle such as used on wagons and stoves and other open slots. Then when the automobile and other mechanical devices came along, bolts tended to be more hidden and obstructions near by and no way to place a square wrench in from all angles. A 4 sided bolt has to be acessed at 90 degree angles and a 6 side at 60 degrees and 12 side at 30 degree angles. I think you can see that a open end wrench on a square head bolt in a hole with only a small opening would never work. A 4 sided lag bolt on a wooden deck is fine but think about a 4 sided bolt holding down the valve cover on a modern engine and you get the point.
Big Jim
09-26-2004 22:40:48
I believe it has to do with technology. It takes a fairly sophisticated forging operation to make a 6 point box wrench but a simple open end is much easier. The open end is well suited for applying lots of torque to a square head fastener, even with pretty loose tolerences. If the local blacksmith could make open wrenches but you had to get anything else from a remore factory, guess what kind of bolts will be used most often?
MAC,IL
09-26-2004 18:05:10
Not long ago you could still buy square head lag bolts, I still got some from way back when. Depending on the head size I have just reversed a socket, worked for me.
Ed H.
09-26-2004 13:46:28
if you get a chance to see on the history channel..."the history of socket tools" , it would help you understand their mind set
Alan Y.
09-27-2004 14:38:53
 Re: Square head bolts and nuts! in reply to Ed H., 09-26-2004 13:46:28
I caught part of that History Channel program series on the development of different hand tools. Very interesting.
Ed H.
09-27-2004 18:09:25
 Re: Square head bolts and nuts! in reply to Alan Y., 09-27-2004 14:38:53
about the history channel "history of socket tools" .....the bottom line was , that the early socket sets broke as easily as those "cheapo" tools you can buy at todays dollar store (rounding off the nut also).....I would assume that a good old ajustable wrench on a square head nut or bolt was the standard at the time..... ....SNAP ON TOOLS changed the standard of socket tools, but were very expensive, just as they are today..... it was an interesting show..... .I wish they would do "the history of the farm tractor"
George G
09-26-2004 12:05:26
third party image
Both of these are for a 1/2" square head bolt,the head would be 3/4". The one on the left is a four point, the one on the right is an eight point.
If you use both, square head bolt and square nut. You don't need a lockwasher.
ChrisH
09-26-2004 10:42:35
The 12 point sockets fit the square head bolts and nuts. ChrisH (IA)
txblu
09-26-2004 06:54:06
I've asked myself that question too. Guess first wrenches (spanners in europe) were flat slotted and a flat wrench on a flat, 4 sided nut gave you plenty of leverage; plus it didn't take any fancy tooling to turn one out.
Good part is like a flathead screw vs a phillips. I like a phillips for starting and screwdriver to screw interface support, but when you really have a hard screw to get out, a quality screw and matching flat blade screwdriver, can really accept the "ft lbs of torque" and get the job done. But I hate flat blades..... ..... ..... ..... ...
Mark
Jim W
09-26-2004 17:57:46
 Re: Square head bolts and nuts! in reply to txblu, 09-26-2004 06:54:06
Maybe they cut them out of long bars of stock?
Jim
txblu
09-27-2004 08:09:27
 Re: Square head bolts and nuts! in reply to Jim W, 09-26-2004 17:57:46
probably. I know that current copper fittings are done like that (hex stock rather than square) then milled to the correct mating dimensions.
txblu
09-27-2004 08:10:00
 Re: Square head bolts and nuts! in reply to txblu, 09-27-2004 08:09:27
er ah brass fittings
