Tool Talk Discussion Forum
Precision measuring tools from Grizzly??
Darren in TN
09-25-2004 08:30:21
Howdy, all.
I"m about to pick up some measuring tools (micrometer set, dial indicator, etc.) and wonder what the consensus might be on Grizzly tools. There prices look really good, which makes me wonder about the quality. Anybody out there using them? I"d appreciate any advice and experience you guys might be able to relate.
Thanks, and have a safe weekend.
Darren
Handyman
09-25-2004 20:56:56
 Re: Precision measuring tools from Grizzly?? in reply to Darren in TN, 09-25-2004 08:30:21
I have a couple of Grizzlys digital calipers they seem to be fairly accurate but then I havent tried to use them for very tight tolerances as of yet. if you have problems with them they do have a good customer service dept with prompt action on defective or missing parts. I also have a lathe and a mill-drill that I purchased from them and so far have had good service from those machines
TimV
09-25-2004 19:15:10
Darren: The only question I have is what are you planning on doing with them? Not to be rude, but if you"re asking this question, my bet is that you"re not going to be doing work that requires top-shelf quality. If so, (and 90% of people, myself included, fall in this category) then the China-made stuff will work fine. I"ve got several China-made dial calipers, a digital caliper, several micrometers, a couple of dial indicators, and various other measuring tools that have worked out fine. A couple of other notes--nearly every cheapie mail-order place (Harbor Freight, Enco, Cummins, Homier, and Northern Tool to name a few) is selling the same stuff, so you don"t have to limit yourself to Grizzly. I"ve had excellent luck with Enco--much faster and WAY more knowledgable and professional than Harbor Freight or some of the others. Also, there are different grades of "cheap", even with the China stuff--you"ll be happier getting a slightly better grade than the absolute cheapest, which frequently are of horrible quality. We got in some dial calipers a few years ago at work that were 0.100" per revolution, but the rack was calibrated for 0.050" per revolution! Needless to say, those went back to the vendor, and the next batch was fine.
Craig in TN
09-25-2004 14:31:31
I'm sure you could get 50 different opinions from 10 different people on this.
As you likely know measuring tools seem to fall into two classes, the first made up of Starrett, Mititoyo and Brown&Sharpe and the other class consisting of "everything else".
I worked as a machinist for a couple of years. With the exception of one or two "tool snobs" everyone in the shop used no-name measuring tools 95% of the time. Coolant and chips will eat a 100$ Starrett just as efficiently as a 20$ Enco.
It's nice to have a few quality tools for precision work but you can get a long way with a China brand 12" dial caliper. Most part dimensions tend to be spec'd at +/-.005 unless you plan on building missles. Also the first time you work stainless on the lathe and chips melt the face out of your dial inidicator, you might be pretty happy to have bought a cheap one.
The company had a full set of high end tools but considering the cost of replacement we only used them when needed for surface grinding etc.
I can't recall if any of my tools came from Grizzly but I'd guess all the import ones are about the same.
Davis In SC
09-25-2004 13:55:46
I am not very familiar with the line of Grizzly measuring tools, but last ones I saw were made in China..... Although the quality of Chinese tools is much better than it once was, I feel it is much better to invest in Starrett, Brown&Sharpe, or Mitutoyo measuring tools. They will last a lifetime if you take care of them. I am still using the tools I bought 26 years ago, some were bought used, all are still very accurate !!! Regards, Davis
Big Jim
09-26-2004 22:15:19
 Re: Precision measuring tools from Grizzly?? in reply to Davis In SC, 09-25-2004 13:55:46
There are some good bargins to be found in quality measuring tools. I wanted a larger caliper for the occasional odd job and picked up a used B&S 26" verneeer caliper for less than $100. New, it went for a little under $2K. I've seen a lot of micrometer sets go cheap because one of the sized is missing and the same listings will have a single of the missing size for a song.
If you have a little time and patience, you can accumulate some good stuff for not a lot of cash.
Davis In SC
09-27-2004 09:48:19
 Re: Precision measuring tools from Grizzly?? in reply to Big Jim, 09-26-2004 22:15:19
Jim, that is how I got many of mine. I still like to buy tools from estates or retired machinists. Buy them all for a few hundred dollars, keep the ones I want, & sell the rest, usually at a profit..... Regards, Davis
