Tool Talk Discussion Forum
Source of hose reel swivels?
IaGuy
09-24-2004 13:01:03
Would like to build my own garden hose reel. Any advice on where I could get the input hose swivel-maybe in 3/4 inch size?
T_Bone
09-26-2004 01:14:04
 Re: Source of hose reel swivels? in reply to IaGuy, 09-24-2004 13:01:03
Hi IaGuy,
Harbor Frieght sells a brass quick disconnects for garden hose that would swivel. You would need to use a set screw behind the collar to keep it from poping apart. Part #34870
If you have a drill press you could also make a swivel with a couple pipe nipples and "O" rings without too much trouble.
T_Bone
Tex Harry
09-26-2004 21:27:20
 Re: Source of hose reel swivels? in reply to T_Bone, 09-26-2004 01:14:04
I got mine from Northern Tools, If I remember right it was less than $4.00. They also sell the whole reel. I got one. But wasn't happy with it, because the tension spring was too weak and it only held about 75 ft of hose. The swivels are with the air stuff. I also saw them at TSC.
Good LUck!
Weirsdale George
09-26-2004 01:39:05
T-Bone,
Could you please explain how you can make a swivel out of a couple of pipe nipples and O-rings? Seems like it could be done with pipe union, but the nipples are throwing me.
IaGuy
09-25-2004 17:54:22
 No luck yet in reply to IaGuy, 09-24-2004 13:01:03
Thanks for the suggestions. So far nothing found. What would you call the thing? Swivel, union? Every hose reel has the sationary input hose connection, then the rotary (sealed) swivel or union and then an outlet for the hose. Could be made in the shop with some time and patience. Just wanted to find somebody who is making them by the thousands and get one! Thanks for the suggestions.
Jim K
09-26-2004 05:29:00
 Re: No luck yet in reply to IaGuy, 09-25-2004 17:54:22
I would call it a rotary joint.
you should be able to get one from surplus supply.
DaveCA
09-25-2004 19:42:27
Full Time Swivel is what I would call it. A hydraulics shop will be able to get one. Maybe McMaster Carr. Don't know where to get an inexpensive one. A hydraulics shop should carry them for big $$$. They are also used on orchard spray rigs, high pressure washer hose reels and fuel and oil pump hose reels, fire trucks carpet cleaning trucks, etc.
Good luck
TheRealRon
09-25-2004 04:47:55
Try www.gemplers.com
Leland
09-24-2004 20:13:25
just type in what you are wanting on google like garden hose swivels.
DaveCA
09-26-2004 10:52:52
 Re: Source of hose reel swivels? in reply to Leland, 09-24-2004 20:13:25
...also continuous swivel.
Good luck
DaveCA
09-26-2004 10:58:52
 Re: Source of hose reel swivels? in reply to DaveCA, 09-26-2004 10:52:52
Sorry Leland,
I thought was viewing IA's post and attempted to respond to it and it ended up as response to your good answer
