Tool Talk Discussion Forum
Miller Regency 250 spoolgun welder question
SteveB
09-22-2004 17:30:06
Is anyone familiar with this welder? I have an opertunity to buy one for 400$ It includes stainless and aluminum set ups. along with about 20 rolls of wire. I basically stick weld but would love a decent mig, Should I buy this? I weld some heavy plate at times but mostly 1/4 steel ect. Thanks for any responces Steve
T_Bone
09-22-2004 23:55:31
 Re: Miller Regency 250 spoolgun welder question in reply to SteveB, 09-22-2004 17:30:06
Hi Steve,
Your talking about the machine (power supply) and the spool gun? Thats a smoking deal. The spool gun can be bought seperate from a power supply so thats why I'm asking?
The spool gun is not used for steel, usually only for AL wire and gets it's current from a CV power supply (welding machine.)
A spool gun is very heavy to use when comparred to a Mig torch and hand fatique sets in easy.
SS and mild steel wire is ran from a spool on the wire feeder head that gets it's weld current from power supply then the wire is fed thru a Mig torch.
Miller does make a machine that was strickly set-up for AL welding with a spool gun and did not have a wire feeder control unit. The wire feeder control unit for a Mig torch will cost about $600 to $1000 depending on the amperage desired.
T_Bone
SteveB
09-23-2004 17:34:11
 Re: Miller Regency 250 spoolgun welder question in reply to T_Bone, 09-22-2004 23:55:31
Hi Tbone
Yes that is for the spool gun and regency 250 welder, Right now it is set up for aluminum with running gear and tank. I know the tanks are leased but I will assume ownership and take over. Can I weld steel with this? I am a stick welder that,s all I know. I have a Lincoln 135 MIG It's a peice of junk.
SteveB
09-23-2004 17:39:49
 Re: Miller Regency 250 spoolgun welder question in reply to SteveB, 09-23-2004 17:34:11
I also forgot to mention I scored on a band saw 100$ 250# anvil 50$ 60 ton arbor press 45$ I got an electric Victor Torch for cutting circles ect, 100$ And I hauled out about 3 truck loads of steel brand new plaates angles and and tubbing for the price of scrap!!!!
