Tool Talk Discussion Forum
Vacuum Pump For AC Service
K-Mo
09-19-2004 06:17:02
With the possibility of servicing the air conditioner on my Grandaughter's car, I got to thinking. Has anyone tried using the current day farm store type oilless air compressor as a vacuum pump? For example, disconnect the output and adapt the intake to connect to the air conditioning system.
K-Mo
lucas
09-29-2004 12:29:09
 Re: Vacuum Pump For AC Service in reply to K-Mo, 09-19-2004 06:17:02
i have the 15.00 pump from harbor freight that runs off of compressed air. have changed over to r134 dozens of cars using it and it pulls a good 30in in a short time.. i even did my home 2 ton unit using it and it worked,,just had to run hose out of the garage.i have 125 lb 60 gal compressor.i dought if a smaller compressor would run it.... lucas
Leroy
09-22-2004 04:32:25
When I was in refrigeration school I built a vacume pump and a refrigerant reclaiming machine from parts from a can milk cooler and a freezer. the reclaimer was noy quite finnished by the time I was out and the next class finnished it and used it in class, worked OK, missed the time frame to get it certified, the pump for vacume would work to a certain extent, it just would not pull quite enough vacume. I hold the Universal 608 licence good for everything except automotive or amonia, automotive takes a 609 licence. But due to new rulls that came into efect at time I got my licence I never set up my shop that I planed and all equipment that I bought is setting unused for years and I was taught that the componet in refrigerant that the goverment is so afraid of is the exact same thing used in your city water treatment plants to treat the water you drink yet there it is not bad and you are ingesting it. The new stuff to do the replacement is so corosive that it will eat anything made of steel.
RayP(MI)
09-21-2004 06:10:57
Last time I had service on an auto AC, my serviceman came out to the location, (he operates out of his truck,) he used a pump which looked for all the world like something salvaged from an old refrigerator. Asked him about it, and that's exactly what it was! He ran it for quite a while, as I had had the system open to replace compressor, and he wanted to be sure it was empty, dry, and held a vacuum.
Di dah dah dah
09-21-2004 03:08:45
My little pump only draws about 25" of vacuum---Is this acceptable and how long should it run???
Allan in NE
09-21-2004 04:52:32
 Re: Vacuum Pump For AC Service in reply to Di dah dah dah, 09-21-2004 03:08:45
Hi,
What a vacuum pump will draw down to will largely depend on your location and your altitude, so there is no one hard fast rule as to what it "should" pull to. Any given pump will not pull the same vacuum in Fort Collins, CO as it does in Tampa, FL.
More importantly though, after you shut the pump off, the system should "hold" that vacuum from before it starts to drop off. I like to see it hold for a good 3 to 5 minutes.
I always let 'em run for 10 to 15 minutes, but I live in the dry arid plains of Nebraska. In a higher humidity location, I�d probably let �er cook for a little while longer to assure the boiling off any moisture in the system.
Just my view and stated as such,
Allan
Charles (in GA)
09-20-2004 20:44:25
About 30 years ago I was given a Kelivinator Drink box compressor, belt driven on a hefty metal base with tht motor missing. It was made to use Sulfur Dioxide refrigerant. I installed a 1/4 horse motor off a old belt drive diaphgram compressor my dad had that had quit pumping, mounted some casters on it and to this day I still use it for A/C work. It will pull 28/29 inches easily. Spits a little oil but I just check the crankcase every couple of years and sometimes add some oil.
Charles
Ben in KY
09-20-2004 12:00:58
A related question here. Harbor freight has an air drive vacuum pump for cheap. Does anyone know if they are any good for AC work ?
Kendall
09-20-2004 13:08:14
 Re: Vacuum Pump For AC Service in reply to Ben in KY, 09-20-2004 12:00:58
I have one of the aspirator type such as you speak of. Its works ok but sure does put a strain on the air compressor. If you're doing home repairs it works ok but if you're doing steady ac work, better to get a real vacuum pump.
Ben in KY
09-21-2004 07:20:28
 Re: Vacuum Pump For AC Service in reply to Kendall, 09-20-2004 13:08:14
Thanks Kendall, that was what I was looking for and suspcted. It should work fine for me, will just be used once a year or so, probably.
HobbyFarmerInWI
09-19-2004 18:42:30
You can use most any pump, the key is letting it run a long time at 25 inches plus of vacuum. The longer you run it, the colder the air will be
Allan in NE
09-20-2004 04:49:27
 Re: Vacuum Pump For AC Service in reply to HobbyFarmerInWI, 09-19-2004 18:42:30
Hi Guy,
Not trying to call you on a technicality or any such thing, but the reason a vacuum is pulled A/C systems prior to charging, is to remove as much air as possible, which in turn, will boil away all the moisture within that system.
It doesn't have a whole lot to do with the resultant A/C temps.
Allan
HobbyFarmerInWI
09-20-2004 19:11:06
 Re: Vacuum Pump For AC Service in reply to Allan in NE, 09-20-2004 04:49:27
Understand your comment, but it will effect the temp results. Spent many years selling automotive AC equipment and seen the effect of longer vacuum run times. What is interesting is the CFM rating of the pump. It makes ALMOST zero diffrence in how big of a pump you use. A 1.5 CFM pump will give the same results as a 7 CFM pump. Yes the 7 pump will get to the desired vacuum a few minutes faster, but that is the only benefit to spending the extra money.
Allan in NE
09-20-2004 19:49:47
 Re: Vacuum Pump For AC Service in reply to HobbyFarmerInWI, 09-20-2004 19:11:06
Sure,
If you feel better believing that, then whoa be it for me to stand in your way.
By all means have at it. :>)
Have a good one,
Allan
HobbyFarmerInWI
09-20-2004 19:10:42
Coloken
09-19-2004 07:45:43
Yes. Maybe not the best, but Better than nothing. Let it pump for a while. Remember even a small amount of moisture is death to an AC. I once screwed up a refrig. by placing my spit finger over the valve- like I do for tire valves. Cured it with the oilless compressor.
