Tool Talk Discussion Forum
Got a weldin' die-lemma. T-Bone,please?
busted welder g
09-18-2004 18:20:10
Was buzzin" together a trash eliminating vessel, and my Lincoln 225 buzzboz quit. Got fan, no spark. Nothin". Every amperage.Took all lead loose and no juice at the first set of couplers. Is there a reset? Manual or automatic ? I was welding with 5/32 6010 on #4 re-bar;not heavy at all. Suggestions,Anyone?? Thanks in advance, Mguy.
old
09-18-2004 21:25:27
 Re: Got a weldin' die-lemma. T-Bone,please? in reply to busted welder guy, 09-18-2004 18:20:10
This may sound dumb but did you check your brakers, My buzz box does that at times and I just reset the breakers and I'm back in to the welding
busted
09-18-2004 23:23:14
 Re: Got a weldin' die-lemma. T-Bone,please? in reply to old, 09-18-2004 21:25:27
theyre OK fan still runs Mguy.
T_Bone
09-19-2004 02:34:47
 Re: Got a weldin' die-lemma. T-Bone,please? in reply to busted, 09-18-2004 23:23:14
Hi Mguy,
The older machines have a thermal overload for when you exceed there duty cycle. For auto reset takes about hour.
If it doesn't reset then it may have burnt the thermosistor out and thats probably buried deep into the transformer.
Since it's a safety then it would wired in series probably on one leg of 230v but they also could have used two thermosistors one in each leg (doubtful).
You might want download a copy of the schematics from Lincoln.
T_Bone
need info 0908
09-08-2005 00:17:01
 Re: Got a weldin' die-lemma. T-Bone,please? in reply to T_Bone, 09-19-2004 02:34:47
Where can I download a copy of the schematics for a lincoln welder? Thanks
need info0908
Busted welder
09-19-2004 10:35:35
Thanks T-Bone, I'm gonna get on this this PM . I got one of them dang summer colds and everthin' is a little slow but I'll get it. Thanks again,Mguy.
