Tool Talk Discussion Forum
horsepower conversion
BSer
09-18-2004 16:15:31
I need to replace a 10 hp 3 phase motor with a gas engine;what does the hp rating on the gas engine or at the PTO need to be?
Paul Janke
09-18-2004 19:11:13
 Re: horsepower conversion in reply to BSer, 09-18-2004 16:15:31
It depends to some extent what the job is. And the elevation at which it will be used. And the temperature. And maybe the relative humidity. Electric can stand quite a bit of short term overload. Internal combustion has less power at higher altitudes. Air cooled power drops off at higher temperatures. On a steady load under good conditions, they can be the same HP.
Roger P.
09-18-2004 17:26:25
Double is the safest guess. Might squeak by with 16hp. When we setup compressors to run on gas, we always double the HP of the motor.
Jim W
09-21-2004 04:40:55
 Re: horsepower conversion in reply to Roger P., 09-18-2004 17:26:25
You could look at what they do with generators - about 2 hp per 1000 watts, which is about 2 mechanical hp in per 1.33 electrical hp out, or 1.5 x. Jim
