Tool Talk Discussion Forum
O T well drilling costs
Leland
09-17-2004 16:26:43
Just called a driller in my area 5-5500 to sink a 40-50 ft 30 in well. seems a little steep but you got to have water.
Charles (in GA)
09-18-2004 19:08:51
 Re: O T well drilling costs in reply to Leland, 09-17-2004 16:26:43
Very big difference between a "bored well" 30" or so, and a "deep well" 4-6-8 inch.
Sorry for the long disseratior that follows but it appears that some folks have never seen a shallow bored well with a jet pump.
Bored wells are done with a auger bit that takes about 15-18 inches deep each time. You come up swing it over, dump the auger drum, drop it back in and take another cut.
When the dirt starts coming out moist (it takes a good feel for this) you stop. Usually 40 to 60 ft around here in west central Georgia. They you act quick, and start setting concrete casing sections, each about 24 inches high and with male/female bevel on the end (very much like concrete culvert sections). You have to act quick as the water intrusion will start the walls caving in. Once the casing reaches the surface another smaller auger bit is dropped down inside and the bottom is cleaned smooth. After that, usually the top is capped with a concrete slab and the pump and a very small tank are set on top and another casing section is set to surround this and a round concrete top is placed. If you want a bigger tank, you put in in the house, or elsewhere. Ocassionally someone wants the pump suspended inside the top of the well casing by three chains and hooks. I don't care for this, hard/dangerous to work on. The casing slowly fills with water that rises up from the dirt bottom and you have a reservoir of standing water. Generally the pump is a shallow jet type with two pipes down. It jets water down one pipe and uses this as an ejector or venturi to siphon more water up. Drive thru the counrty side in these parts and virtually everyone has one. Many of the older homes in town nearby still have the wooden shed roof and the rope winding drum with a galvanized bucket tied to it. Just drop it in and reel up a bucket of cold water to sip on.
Deep wells pass thru the bedrock and the casing is set to the bedrock. Deep water is drawn from the aquifer below the rock and sometimes you hit an underground stream, sometimes it requires a extreme high pressure cracking of the rock to get the well to flow. This type of well has a pump at the bottom of the casing pushing water up the pipe.
My private subdivision has three deep wells. all have 8 inch steel casings and five horse pumps with inch and a half pipe. Two of the wells have 1500 gallon pressure tanks with an air head on them, the third has a barely workable system with four huge bladder tanks plumbed together. This well had problems from the get go. It has so much iron in it that it looks like red mud coming up. We use a unique sand filter and aeriator system to remove the iron and it works well. This well has a 600+ ft hole. The other two are each around 500 ft and one I know has 17 sections of pipe, 21 ft each (357 ft) in it, I watched them put it in.
Bored wells are very suspectable to going dry or very low levels during droughts as they depend on surface water filtering thru the soil directly to the well. Deep wells are more stable water level wise as they depend on the deep aquifer which here at least is fed from the appliachian mountains, hundreds of miles away.
Charles
Leland
09-18-2004 20:39:24
 Re: O T well drilling costs in reply to Charles (in GA), 09-18-2004 19:08:51
Also we can't have many deep wells here almost whole county is undermined you would hit a mine shaft. thats why $400,000 homes arwe sinking and getting swallowed alive.
Leland
09-18-2004 20:34:16
Charles now they use 20 corragated fiberglass pipe not tiles they are belled for a good seal. They also have a bottom to seal out sediment for cleanwater much better than concrete go to www.gbfiberglass.com. They cap wells at 10feet then pour powered clay and pack it to keep out ground water out .
Bus Driver
09-18-2004 15:59:47
John A below posts prices that are about the same as my part of NC.
Pete - IN
09-18-2004 11:43:41
I am curious. What on earth are you supplying with water to need a 30 inch well? The city water supplies in NE Indiana don"t even use that big of a well.
Leland
09-18-2004 20:42:08
 Re: O T well drilling costs in reply to Pete - IN, 09-18-2004 11:43:41
These are shallow wells here large tubes for large reserve to fall back on usually 1000-2000 gals
T_Bone
09-18-2004 08:12:27
Geezs you guys feel lucky as here it's $25ft complete for a 4", PVC cased 200ft. They have them standing in-line for 30-days at that price.
We drill 36" dry wells for our spetic systems or did as now they require leach fields. Thats a heII of a auger to drill a 40ft hole and is something to watch.
T_Bone
Allan in NE
09-18-2004 05:24:19
Hi Leland,
$4500 to $6K here, depending on extras needed.
We usually drill to 180 feet, static water level is at around 60.
Allan
PJW
09-18-2004 04:57:08
30" well is a big diameter. The prices the other guys write about are for 4-6"wells. Maybe your price is not so bad.
Leland
09-18-2004 20:20:33
 Re: O T well drilling costs in reply to PJW, 09-18-2004 04:57:08
A 30 in well around here is common old one is 36 in they usually hit water at 25-25 feet, The rest is a reserve we have a lot of shallow aquafers in IL some are more like under ground lakes. In Havana IL in 93 during the great floods water was pouring out of ground covering hundreds of acres , up there you hit water at 2-3 feet all good water all sand 2-300 feet deep. A archeologist once told me the OHIO river ran way up here but a earthquake changed its path to 300 miles south just like the missisippi river went 100 miles west part of the Ill river from peoria south is the ole miss so water is abunbant here just have to pay thru nose to get it.
t
KURT (mi)
09-18-2004 03:45:17
I paid about $4000 to a well driller 4 years ago. 120 ft. deep. That is the total price for everything. Shop around and see what prices you can get.
John A.
09-17-2004 20:49:10
Leland, Here in Central Texas, a combined cost of "drilled & cased" of $8.00 to 10.00 /ft. Average deapth of most new wells around here is about 450 to 500 ft deep. So a well 500 ft deep, with a $9.00/ft charge = $4500 . That doesn't include the cost of the pump, pipe, & wire.
Later,
John A.
Joe (Wa)
09-17-2004 23:03:12
 Re: O T well drilling costs in reply to John A., 09-17-2004 20:49:10
Olympic peninsula, W.WA 5 years ago $21-27 ft. Hole & 6" casing only.
Charles (in GA)
09-17-2004 19:49:50
In central Georgia a bored well runs $2500 to $3500, usually 60 ft or so with pump, etc., but generally guaranteeded water so depth doesn't matter.
Drilled well, usually a fixed price, depth doesn't matter, runs $4500 to $5500 including casing, pump, etc. Could run anywhere from 200 to 600 ft., guaranteed water, so depth doesn't matter.
I've talked to several well companies in the past couple of years. I am on a private community water system but still considering my own water source as a backup.
Charles
Charles
Wayne in illinois
09-17-2004 19:23:15
Can't help on the well cost's but would just like to add that thank goodness the county came though here with water last year .Before that we hauled water from about 5 miles away for the last 14yrs .We have 2 played out wells here on this old farm and sure couldn't see the cost of drilling as we knew that county water was coming .Feel's good not to have to worry about pumps or any of the other stuff that goes along with wells .
Leland
09-18-2004 01:56:30
 Re: O T well drilling costs in reply to Wayne in illinois , 09-17-2004 19:23:15
Wayne just north of Springfield water is 2 miles west of me also new tower . The city of athens won't run us water so I have to do something. bad part is city water would only cost 2500 to hook onto.
Wayne in illinois
09-18-2004 21:04:08
 Re: O T well drilling costs in reply to Leland, 09-18-2004 01:56:30
Hey Leland well your location makes us about neightbors LOL I live about 70 or so miles straight west of Springfield .Live outside of Barry ,illinois .Shame that you couldnt hook on to that water alot cheaper then that .Hope it all works out for you as i know its frustrating without a good supply of water .
Sincerely Wayne
Leland
09-20-2004 16:17:20
 Re: O T well drilling costs in reply to Wayne in illinois , 09-18-2004 21:04:08
Thanks
nwb
09-17-2004 18:12:05
I guess I'm lucky. We paid $3500 last summer. Cost was of 140' deep, 8",new pump, new hydrant and hook up to the house. I'm not familiar with 30" wells or the shallow depth. Maybe it is a different type of well than around here(NW Ohio).
Bill Drew
09-17-2004 17:27:32
Cost us $4,200 last year to drill an 80 foot well (water at 40 feet) including the pump, line to the house, and pressure tank. Northwest Wisconsin.
Leland
09-17-2004 18:06:58
 Re: O T well drilling costs in reply to Bill Drew, 09-17-2004 17:27:32
I guess not that steep our bid also includes pump and lines also but a lot of hardpan here
