Tool Talk Discussion Forum
Building a Disc sander
Dave2pa
09-17-2004 09:07:43
Been thinking about Building a Disc Sander ,maybe a 12 inch one,, Does anyone know of a place to buy the Disc itself ,
thank you Dave
rchva
09-22-2004 14:40:35
 Re: Building a Disc sander in reply to Dave2pa, 09-17-2004 09:07:43
i had a Fine Woodworking book somewhere that had several plans for large disk sanders. might fine it in a good library.
cw SATX
09-20-2004 08:05:20
Dave, check out the following from ShopSmith
WWW.shopsmith.com
go to Catalogs - Aaccessories
On left side of page go to
Mark V Accessories
On right side of page go to Sanding
In Center of page go to 12" Steel Disc
cw
Ryan-WI
09-18-2004 14:32:22
One of the catalogs I get has a flat plate that can be used as a sander in a table saw. I will look to see which supplier Monday when I am back at school.
Chris(WA)
09-18-2004 14:09:41
Take a look at www.grizzly.com. For $129.95 they have a ral nice unit. Unless you have all the parts lying around AND your time is worth nothing this is hard to beat!
JoeK
09-17-2004 17:36:50
I run several homegrown "direct drive" bench motors for wirewheels,buffers,drill chuck,carbide disc etc.On these I use a threaded shaft motor adapter.I have been looking for a disk type plate,but have been unable to find anything pther than the plates for commercial models,which are way pricy or won't match up with my motor shaft,so heres the current game plan.
