Tool Talk Discussion Forum
Bush Hog SQ 720
S. White
09-15-2004 16:41:22
How do you loosen the nut to remove the old blade? I bought a 1 11/16 socket for this and have even pounded it with a sledge hammer trying to loosen it. However, It is still in the same position that it came in.
John A
09-15-2004 21:32:43
 Re: Bush Hog SQ 720 in reply to S. White, 09-15-2004 16:41:22
S White, First you need a 3/4 drive breaker bar and that socket. Also a 8ft long, 2in cheater pipe. If the pipe doesn't break it loose, Then get your torch heat the nut then turn the nut off. If this doesn't work ....tourch the nut off. then drive the rest out.
Later,
John A.
