Tool Talk Discussion Forum
Power Hand Saw
Ramond
09-14-2004 07:47:26
Has anyone ever used a power hand saw like the Bosch model 1640VS? I need to cut some wood baseboard and chair rail while they remain in place and thought this type of saw may be the best choice to get a good, straight cut. Any comments or advice would be appreciated.
Tip
09-16-2004 11:41:09
 Re: Power Hand Saw in reply to Ramond, 09-14-2004 07:47:26
Hey Raymond - I think you had this response before, but a simple dovetail saw is the best solution. Why are you going to waste money on a power tool that you will use once when a good old fashioned hand saw will do as good of a job? Japanese style pull saws have kerfs as thin as 1/64th of an inch and cut as precisely as the operator operating them.
A well sharpened chisel will also do the trick.
If you are insistent on using a power tool, buy a Dremel with a router base, use a straight piece of wood as a fence and get a fine bit - should do the trick.
Tip
Ramond
09-17-2004 04:39:21
 Re: Power Hand Saw in reply to Tip, 09-16-2004 11:41:09
TIP, Thank you for your response. Yes I did post previously. At the time I was unaware that Bosch made a "power hand saw". I did take your advice and purchased a dovetail saw and I will probably end up using it to cut my trim. Thanks for taking the time to answer my post. Take care.
BrokenFences
09-15-2004 16:22:13
I'd use a sawzall with a very fine tooth, wide blade.
OGGIE
09-15-2004 10:28:13
POWER HAND SAW IS A CONTRADICTION IN TERMS
DON'T GUESS I EVER HEARD OF ONE.
Ramond
09-15-2004 12:29:21
 Re: Power Hand Saw in reply to OGGIE, 09-15-2004 10:28:13
I am sorry, but that is the name that Bosch uses. I agree with your interpretation. Take care.
