Hi AD, What I do on a low flow wells is too pump the well into a storage tank, say 250gal, then pressure pump from there to the main feed line to the house. The well pump controls are set to draw the static head down to above deep well pump level then shut off. A timer control usually works best here along with a series warwick control (a J-K flip-flop controller). Static head is the water height setting in the well casing. What this does, when the timer says to, then it completes the circuit to the warwick thus the deep well pump cycles on until the warwick tells the pump too shut off or the timer shuts the pump off. Until the storage tank becomes full, the deep well pump always shuts off on the timer so you always pump the static head. You can also series warwick controls. That lets you add a safety to the deep well pump so it doesn't pump dry. The new pressure pump will be controlled with a standard pump pressure control. If you don't know well controls, then you will need to hire this job out. Print this and give it to your pump control man to read. He will understand my control method, if not then you have the wrong control man. A deep well, I'm using the term deep well to differerence between the new pressure pump you will need, set up with this type of well system saves the deep well pump life as well helps too develope the well. A non-bladder pressure tank is good until it starts leaking. If the tank is not leaking then you need a new air sniffer. A air sniffer adds air to the pressure tank as the water is pumped. You can never have too large of pressure tank. Too small of PT will shorten the pump life. T_Bone
