Tool Talk Discussion Forum
Grand AM brakes
jaybird
09-13-2004 05:35:20
In putting new pads on my 2002 Pontiac Grand AM the caliper bolts came right out, but the bolts that hold the mounting bracket to the steering knuckle are seized and won't budge.This bracket has to be removed to remove the rotor. All of these parts are aluminum so heating with a torch is not an option. Any ideas appreciated.
RJ-AZ
09-13-2004 19:26:19
 Re: Grand AM brakes in reply to jaybird, 09-13-2004 05:35:20
Aply a LITTLE heat maybe with a small propane torch just to bring it up to a little hotter than comfortable to the touch. I beleive they are 18mm and you need a good 6 point socket and a 1/2 dr breaker bar. I have a 18mm impact flex socket but then I work on stuff like this stuff everday and sometimes twice on Sundays.
jaybird
09-14-2004 05:04:16
 Re: Grand AM brakes in reply to RJ-AZ, 09-13-2004 19:26:19
The bolts that I have take a 12mm socket. Thanks for all the info. I was leary of snapping the heads off the bolts.
Allan in NE
09-13-2004 06:18:43
Hi Jay,
No, if you are talking about the bolts that I think you are, they are not seized; they are just very, very tight. This is just the way they are.
I always had to use at least a 1/2" breaker bar on the dudes.
Allan
EddiePetty
09-13-2004 06:36:36
 Re: Grand AM brakes in reply to Allan in NE, 09-13-2004 06:18:43
AND..... if its the original installation, they're locked down with a factory locking compound !!!! VERY TIGHT !!!!
Allan in NE
09-13-2004 07:32:29
 Re: Grand AM brakes in reply to EddiePetty, 09-13-2004 06:36:36
Hi Eddie,
Yepper, I forgot to add that part. :>)
Allan
