Hi guys...Heard my water pump kicking on 30 seconds/off 30 seconds. Knew I had a slow drip (damp basement anyways so I hadn't hurried to fix it...) from a relief valve between the pump & pressure tank, so I thought if water was dripping out maybe it was letting air in. So I replaced that...still the same problem. Doing more diagnostics: Turn power off, you can hear "flow" -- water I believe, not air -- back towards the pump. Turn the quarter-turn-valve by the pump off, and the flow stops and the pressure guage on the pump immediately goes to 0 psi. If you turn power on with the valve off, the pump rapidly (several times per second) cycles on and off. I do have pressure in the tank -- haven't put a guage on it, but with the pump off and the valve by it shut, I can still flush the toilets, brush teeth, etc. I've also put my finger against the garden hose outlet by the pressure tank, can't feel any leak there; and shutting the quarter turn valve that goes to the house doesn't solve the "leak" either. I don't see any water around the pump -- at least not at the rate it would be going out with the flow I hear. Like I said, basement is pretty damp all summer long so there's a lot of condesation, etc normally. I'm thinking at this point there must be check-valves in the pump that prevent the pressure tank from back-feeding through it, and that is stuck open? Where would I look for such a thing? And would the foot-valve allow such back-fed pressure to escape???? Thanks in advance, Matt
