Tool Talk Discussion Forum
1967 evinrude outboard boat engine gas oil ratios
Berlin Fisher
09-11-2004 16:18:04
I posted a message last night and since have found the exact engine from a serial # search I have a restored 1967 evinrude lark 40hp engine and I am trying to learn the gas to oil ratio on this engine. Any help would be great.
THANKS!
Steve Henderson
09-12-2004 03:11:52
 Re: 1967 evinrude outboard boat engine gas oil rat in reply to Berlin Fisher, 09-11-2004 16:18:04
I own a repair service for outboard motors in northern Indiana. We work on more OMC (Johnson & Evinrude) motors than anything. The factory changed the oil/gas ratio from 24:1 to 50:1 about 1960 when they changed from the old double-hose (pressure tank) fuel feed system to the single hose system that uses a fuel pump. If your Evinrude dates from 1967, you can be sure it was designed to use a 50:1 mix.
Also: In my opinion, the new OMC TCW-3 oil makes it possible for even the older motors to use 50:1. I have a 1955 Evinrude 15 hp on my fishing boat and I use a 50:1 mix in it all the time. I use only the OMC TCW-3 oil. In three years I've seen no damage and no lessening of efficiency.
I hope some of this helps.
Steve Henderson
Indiana
Berlin Fisher
09-12-2004 07:13:18
 Thanks to all who helped in reply to Steve Henderson, 09-12-2004 03:11:52
thanks!!!!
Mike in Il
09-11-2004 21:59:51
I have 1969 18Hp Evinrude that is 50 to 1 mix. Hope this helps.
Leland
09-11-2004 19:48:30
Had a 66 25hp and the mix 50-1 yours should be the same
Gene Davis (Ga.)
09-11-2004 19:36:00
Dont know for sure, but expect you could find out from doing a search for some of the antique outboard forums on Google maybe. It is probably going to be in the range of about 24:1 However don't take this as the final answer. LGD
Gene Davis (Ga.)
09-11-2004 19:33:02
