Tool Talk Discussion Forum
1967 larson 40 hp out board gas to oil ratios
Berlin Fisher
09-10-2004 21:54:34
I just purchased a 90 % restored Larson pleasure boat. I am trying to find the gas oil ratio mixture for the out board engine which runs GREAT!
does anyone know the answer? The engine is 40hp the gas tank is 5 gallons. Thanks
berlin
09-11-2004 16:20:01
 Re: 1967 larson 40 hp out board gas to oil ratios in reply to Berlin Fisher, 09-10-2004 21:54:34
thanks
tim in wi
09-11-2004 07:32:30
32/1 30w oil will be stock recomend mix. babit b-rings you can use 2cy mix also at 32/1 gl tim
Allan in NE
09-10-2004 23:45:55
Berlin,
What engine? Chrysler? 4 cyl Evanrude or Johnson? (Same thing, really) 40 horse sounds like it could be a 4-pop Merc?
'67 would put it before most manufactures switched over to the 50:1 and as I recall, Merc was the first to switch in '69 or '70.
Me thinks ya run em at around 25:1.
If I'm wrong will someone please correct?
Allan
txblu
09-15-2004 11:31:04
 Re: 1967 larson 40 hp out board gas to oil ratios in reply to Allan in NE, 09-10-2004 23:45:55
16:1 ....1 qt to 6 gal.
McCullogh in the '60's. Had a 100:1 in a 4 oz can that treated 6 gal. Had one did it.
Mark
