Tool Talk Discussion Forum
Phase converter to run a 3ph. welder?
Loren
09-09-2004 20:32:40
Does running a welder from a converter work well or bad idea? Loren
buickanddeere
09-10-2004 13:04:49
 Re: Phase converter to run a 3ph. welder? in reply to Loren, 09-09-2004 20:32:40
The large 600 vac welders around here plug into the three phase receptacle. However inside the welder it's single phase wiring using only two of the three phases.
loren
09-12-2004 00:07:26
 Re: Phase converter to run a 3ph. welder? in reply to buickanddeere, 09-10-2004 13:04:49
Hmm. Wish I also understood more about that. Do you understand how the changeover is worked out inside? Loren
buickanddeere
09-12-2004 15:25:21
 Re: Phase converter to run a 3ph. welder? in reply to loren, 09-12-2004 00:07:26
The welder I wired up had terminals inside for 208/240, 480 and 600V. Single phase with just two live leads and the chassis ground. Oviously a rotary convertor would be a waste of time & money there. Now it's possible that some high frequency or DC machines may use all three phases?
Loren
09-12-2004 19:58:39
 Are you familiar with the R3S Lincoln? in reply to buickanddeere, 09-12-2004 15:25:21
That's what I've got. I'll ask out welding supplies dealer and see if maybe they can tell me if it can be wired single pahse. Loren
paul
09-11-2004 12:05:24
I was wondering how a 3ph welder works. I understand the rotating deal of a 3ph for a motor, but a welder is just a spark, can't see where 3ph would actually help it? But then, I'm an electical dummy.....
--->Paul
Dieselrider
09-10-2004 03:57:12
We have a 10 HP rotary and run a three phase miller on it pretty regular and it seems to work real good.
Big Jim
09-09-2004 20:43:03
I've been told 3ph welders won't run in the inexpensive, capacitor-style converters at all but you should be OK with a rotary type. I've been thinking about getting one just on general purposes because used 3ph stuff goes so cheap.
Bus Driver
09-10-2004 05:00:34
 Re: Phase converter to run a 3ph. welder? in reply to Big Jim, 09-09-2004 20:43:03
I strongly suspect that Big Jim is correct about the need for a rotary convertor for the welder- unless the welder is the motor-generator type. The static convertors depend on the motor to help with the conversion.
