I'm just a simple dirt farmer, so I don't know beans about it & I'm not qualified.... But I have an issue with part of your comments. You say: "I suspect most 240V single phase connection would use the 4/0, 4/0 and 2/0 with the 2/0 as the ground ( neutral )." I do not think so! The neutral wire & the ground wire are _NOT_ the same. It is easy to make electricty work without the ground wire; and it is east to make the ground wire carry the neutral load. Works just fine. But it totally defeats the point of the ground wire, and sets up a dangrous condition. These days, I believe you need to run 4 wires from your meter/ pedistal box*, or 4 wires from your main panel if that's all you have, to every other sub-panel. You need the 2 hot wires, both 120v. Together they give you 240v. You need the neutral wire, which is the return path for either of the hot wires to form a 120v line. And, for the past several years, you need a seperate ground wire to make everything safe. Likely this is the lighter wire of the 4, but I'm not sure. This wire connects to all bare metal of all your appliances; all the metal boxes in all your wiring; all the round 'third leg' connectors in all the outlets; and so on. This wire gets isolated from all other wires except one location - the main panel (or disconnect) it gets tied onto the same ground bar as the nuetral wire - only this one place. But, it never ever should be confused with the nuetral, or interchanged with it, or be connected to any other neutral buss anywhere else in the system. (With an asterik for certain out-building setups on a farm site where no plumbing is shared, etc. - bet that is wiped out in the '05 code.) In a good world, this ground wire will never ever be used. Ever. Terrific. You'll never know it was there, or it was wired wrong, or is missing.... BUT, if there ever is a problem in your wiring, this wire will save your life or your building from burning down or your kid's life or your grandkid's life 40 years from now.... But, _only_ if you wire it up properly! It needs to be isolated from the other wires, except at that one connection point in the main panel. Which, unfortunately, makes it look 'just like a neutral' wire. But it shouldn't ever be confused as one. In days gone by, each panel or building had it's own ground rod (still do...) and this was used for the ground wire, not all run back to the main panel. But they found that electricity was using water pipe & other connections between buildings and defeating the whole safety point of the ground system - as well as too much resistance in the earth so you or I would still get a big jolt. So now to make it work, you need the ground to be a seperate wire all the way through, with only one terminal connection in the main panel. Anyhow, that's my simple understanding of it. I could easily have some stuff wrong, so don't rely on me - find out the real deal from a good source. No one really commented on the aluminumn wire either - it makes good enterance cable, but it does not clamp well to lugs. It likes to change size as it heats & cools, and reacts with some metals. This leads to arcing, which of course leads to fires.... Be _sure_ all your aluminumn connections are done with the special connectors & grease & so on. Don't just screw them in without checking this. Aluminumn requires special care on this. --->Paul
