Tool Talk Discussion Forum
Special Power Saw
Ray Schroll
09-08-2004 04:31:10
I would like to know if there is a special power saw that can be used to cut trim while the trim is in place/installed. I have chair rail and baseboard that I want to cut in order to trim out several door openings. I prefer not to have to remove the chair rail or baseboard. I am afraid that I will not get a clean, straight cut using a circular saw plus I want to avoid damaging the wall surface. Any suggestions would be appreciated. Thanks.
Tip
09-08-2004 15:08:39
 Re: Special Power Saw in reply to Ray Schroll, 09-08-2004 04:31:10
Forget power....and use a good old fashioned back saw. A japanese pull type dovetail saw will also work well. You can purchase the Japanese dovetail for around $30. Practice a bit and then take your time, make sure you don't have any nails in the way and you can get close to perfect cuts.
Tip
