Tool Talk Discussion Forum
OT - ooouuu what is that smell. . .
ShepFL
09-07-2004 21:18:43
Just coming out of the aftermath of Frances. Got away relatively unscathed. Minor wind damage to trees, found some leaky windows in the new house and LOTS of rain. The only unexpected thing we encountered was some return from the septic system.
Anyone here ever install a septic backflow valve to prevent sewer backup? Inside or outside? Preference?
We are still without power and our place got somewhat flooded. We ran generator to keep freezers going and to keep septic sump pump going. Early, early this morning generator ran out of gas and sump pump quit which resulted in sewer backup into master bath and bdrm. Mostly just stinky water and mad hatter Mrs.
Also, can a floating floor drain plug at the lowest point (master bath) be used in conjunction with backflow valve? Want to try and prevent a repeat of this fun :)
Thanks!
john nelson
09-08-2004 20:41:46
 Re: OT - ooouuu what is that smell. . . in reply to ShepFL, 09-07-2004 21:18:43
I have used two types, a flapper and a ball which floats up when the line is full, it requires a 4" seperation in elevation the flapper fits in a more level line. I like the ball type best if you can use it. Some states and cities have regulations prohibiting them, or require a vent down stream from them. John
VaTom
09-08-2004 05:51:12
Hi Shep,
I was hoping you were writing about smelling fresh bread in the oven after the power was restored. Guess not.
Good to hear you're mostly OK. No idea for you about a check valve. We're 75' higher than our septic, not an option for you. I'd feel real uncomfortable relying on electricity to have a pleasant home.
What's left of Frances is dumping several inches of rain on us today. Nothing like you got, but there'll be flooding.
KURT (mi)
09-08-2004 02:43:31
You may want to get your tank pumped out, at least that way it wont back up into the house for a few days or until the tank fills up again.
