Tool Talk Discussion Forum
weilding with 7018
vince
09-06-2004 20:19:20
I WAS WEILDING WITH 7018 ROD ON 3/4 INCH STEEL IT WOULD GO 1/8 INCH AND THE ARK WOULD STOP THEN STICK ON THE STEEL 5/16 ROD TRYED ALL KINDS OF AMP SETTING ALL THE SAME 6018 ROD 1/8 WORKED WELL WHAT IS WRONG WITH THE 7018
Andy2
09-08-2004 09:33:03
 Re: weilding with 7018 in reply to vince, 09-06-2004 20:19:20
Are you useing the right 7018? 7018 rods are meant to work in a DC welder. If you have an AC welder you need to use 7018AC rods. Regular 7018's will react like that in an AC welder.
T_Bone
09-08-2004 03:58:44
Hi Vince,
Double check what electrodes you were using. 1/4" is tops as far as I know in the popular electrodes types and I don't think they ever made a 6018.
T_Bone
txblu
09-07-2004 05:50:38
7018 is a shallow rod. 6011 is a deep rod. With that said, I use the 7018 for almost everything, but usually don't weld thicker than 1/4.
If you want to weld thick material, Vee it and fill the Vee with 7018 (several passes). Such a clean rod, easy to clean up after. Love it.
Mark
TonyD
09-07-2004 04:01:32
Hi Vince. The first thing that comes to mind, when you say 5/16� rod is damn, the second thing is rod oven. See 7018 has an iron powder flux. The rod will work a whole lot better if it has been in a rod oven for a least 24-hours. With out going and getting my AWS books, a good rule of thumb. When you take the rod out of the oven with out a glove, you don�t want to walk very far with it! This is not to say you can�t weld with 7018 if it is not baked, I have poured water out of a can of 7018 and had to use it that way, sure the quality of the weld is in the toilet. But it works better pre heated!
