Tool Talk Discussion Forum
Welding Cast Iron Wheel
Jason(PA)
09-06-2004 16:54:24
Im restoring an old hit and miss engine. Today while removing the one fly wheel I chipped a small part off of it. I have heard welding Cast Iron can be tricky. I have a mig welder could this be used? The part is not going to be under any strain so even if the weld wouldn't be a strong one that would be ok. This is just going to basicly be a cosmetic fix up. Thank You!!
T_Bone
09-07-2004 14:49:42
 Re: Welding Cast Iron Wheel in reply to Jason(PA), 09-06-2004 16:54:24
Hi Jason,
Your probably dealing with cast steel and not cast iron and it should weld ok with Mig for that project.
Preheat the weld zone to 500� (wheel weight melts at 500�) then weld, then air cool slowly (cover with sand) should do it no matter what your dealing with. Grind flush.
Any weld cracking then post back here BEFORE you spin that sucker.
T_Bone
Jason(PA)
09-07-2004 16:41:25
 Re: Welding Cast Iron Wheel in reply to T_Bone, 09-07-2004 14:49:42
Is there anyway I could tell the difference from cast Iron or Cast Steel? Thank You
T_Bone
09-08-2004 03:37:48
 Re: Welding Cast Iron Wheel in reply to Jason(PA), 09-07-2004 16:41:25
Hi Jason,
Cast iron will have a red shower of sparks kind of dull red starburst type.
Cast steel will have bright yellow sparks.
T_Bone
Kendall
09-07-2004 08:50:20
Another link on welding cast iron.
If its just cosmetic, would brazing the piece back on work??
Kendall
09-07-2004 08:48:12
here's a link on welding cast iron
Fritz
09-06-2004 22:52:39
Don't have a lot of experience welding cast iron, but I do know that the best way is to purchase rod for an arc welder specifically made for this. Also, very important to heat up the piece with a torch prior to welding to prevent it from cracking. Good luck!
