Woodcutting blade on a 14 abrasive chop saw- why not?
Leon K
10-27-2000 12:58:26
I just bought a Milwaukee abrasive cutoff machine- it is designed for a 14" abrasive wheel.
I was thinking that I'd be able to also use it for crosscutting thick stock, like 4x4's if I put a 14" miter blade in it.
However, the instructions explicitly say not to use a saw blade of any kind in the machine. I find this suprising. Any idea what would be unsafe about cutting wood on a machine like this (except that the fence is pretty tiny)?
Leon K
10-30-2000 06:52:08
 Re: woodcutting blade on a 14 abrasive chop saw- why not? in reply to Leon K, 10-27-2000 12:58:26
Thanks for the comments. I will check rpms before I consider a saw blade on the machine.
I am building a timberframed woodshed, and a large diameter chop saw would be REAL handy, so I may give it a try.
The milwaukee cutoff machine has a very nice steel retracting blade gaurd- better than the one on my old Makita 10" miter saw, which is plastic and binds up all the time. This is one of the older, simpler gaurd designs that (supposedly) retracts when it comes in contact with the work. Because it does not work well, it is more of a hazard that a safety device.
I suspect that the no-saw-blade statement is to satisfy Milwaukee's legal dept., and if I am very careful it will be a safe operation. I'm going to call them today and see if I can get an answer from a tech.
Joe Evans
10-29-2000 20:12:34
The other posts mentioning the shrouding of the blade for safety should be heeded. However, the company I work for got a piping contract to install many thousands of feet of Sch80 CPVC pipe. I rigged one of our 14" abrasive saws with a 14" diameter 80 tooth carbide bit for cutting this pipe on the jobsite. It worked splendidly. After that job was done, the saw and blade cut many 4x4s for a rigging job we had.
John in Abq
10-28-2000 09:44:52
My new Delta 10" miter saw blade is marked 6000 RPM max. And as the blade diameter goes up the rated RPM goes down. How much I don't recall. Also as the others have said, the guard systems on the wood cutters are much more extensive these days.
HTH
John
Scott Green
10-28-2000 05:30:25
For starters , the bearings are much more rugged than power miter saw bearings. So you know that isn't the problem. I would say it was a safty factor. I don't remember the RPM's of each , as I sit at the computor , but to high of RPM's on the chop saw may be another factor. The wood blade may default or not properly clean itself. Most saw blades for wood have a MAX: RPM rating marked on the blade. I would guess it is RPM's.
Dale13
10-28-2000 01:43:55
I've cut wood with the abasive blade,makes a smooth cut but I would'nt cut too many 4x4's. Makes a little smoke.
Bruce
10-27-2000 20:55:48
Check the H.P. requirements to spin a 14" woodcutting blade vs. a chopsaw abrasive wheel. Maybe the motor would not have sufficient power. Also, as mentioned previously, check rpm ratings of saw and blades. === However, IMHO, the manufacturer does NOT want you to use a sawblade, because there is probably NOT sufficient guarding of the blade. Miter saws on the market today have extensive shielding for the blade. It is, after all, a lawyer's world!
TomH
10-27-2000 17:20:11
Check the RPM, might to turning too fast for a saw blade. Probably a good idea to follow the directions anyway.
