Tool Talk Discussion Forum
lift for garage
Steve-Maine
09-04-2004 14:12:29
I looking at buying a lift for my cars and pick-up truck. I want swing out arms and high enought to park another car under it. What is a good brand to buy. Thanks
Dayne Lancaster
09-07-2004 07:35:47
 Re: lift for garage in reply to Steve-Maine, 09-04-2004 14:12:29
I have a Mohawk lift 9000# Tomahawk total hydraulic no cables or chains anywhere. I would reccomend checking them out. They are built in the USA and are very heavily built. They are also very user friendly and if the slide blocks ever need replaced you can do it yourself.Check them out At Mohawklifts.com
Johnski
09-04-2004 21:31:21
There are lots of them out there now so I can't suggest a brand but here are some thoughts. Get a 9000lb to 12000lb they are not much more $$ and you'll be glad for the extra cap. Get assymetrical lift arms, this lets you get the door open farther after driving onto the lift. Consider if you want an open top or clear floor type, they all have cables or chains running from side to side. Open top is better for tall vehicles and the clear floor type is better for working under as there is nothing to get in the way of jacks or support stands etc. One last thought, if you're thinking used, check prices on any parts,chains cables etc, needed as they can add up to more than a new unit. HTH
Johnski
09-04-2004 21:28:56
thejdman01
09-04-2004 18:39:27
alm
TR
09-04-2004 18:10:36
I work a lot with " Mohawk' and "Rotary" above ground lifts lifts. Both are of HIGH quality. Would recommend them always.
Jack-Iowa
09-04-2004 17:08:46
All sorts of lift styles ,fast and friendly ,best prices I have found.
jack
Bowlegs
09-04-2004 16:36:45
found this site a while a go but have no idea how good they are.
Bilko
09-04-2004 18:23:46
 Re: lift for garage in reply to Bowlegs, 09-04-2004 16:36:45
My uncle has a bend pak with the swing out arms. He loves it and wishes he would of realized how nice it is to have because he would have purchased one 20yrs ago. Mike
