Hi Butch, To use a forming die you need 8 times the metal thickness for die clearance. If your dies are to close mated, it will cause the metal to rip and tear as it forms. I would would make the float in 3pcs. The main body I would break the 1" sides then open to form the 1/2 round, then hand form the 90�'s, then lap and solder. I would then add the end pieces and solder. What your doing is preforming the sharp 90� bends so after rolling the 1/2 round, the 90� corners will return to 90� very easy by hand forming. To make the end pieces, cut your patteren about 1/8" larger then use a piece of steel round stock as a dolly and hammer form a 90� inside lip. This lip will attach to the main float body for easy soldering. When dolling this inside lip up, only dolly up about 10� at a time then repeat until 90�. This keeps the lip metal from stretching and folding. To solder a closed vessle you need to leave a small air vent, solder all joints, let cool, then solder the air vent hole. IF you don't leave a air vent then the heat from the soldering process will cause the inside chamber to fill with pressure and you will never get the joints to solder. Your brass shim stock is also tempered. To anneal, heat to a null red then quench in water. This will make the shim stock form alot easier. T_Bone
