Tool Talk Discussion Forum
So you own a welder! Now what?
TonyD
09-03-2004 05:56:21
Hey guys, after reading T_Bone�s reply to Vince�s question on how to weld 3/4� thick plate. I got to thinking. So I�m going to climb up on my soapbox and preach a little here. There is a lot more to welding than just knowing how to pull the trigger on a wire feed or strike an arc and know how to carry it. JOINT PREPARATION! I was almost killed about 10 years ago, all because a fellow welder did not know, or take the time to bevel a 3/4� plate that was going to be used as a pad eye welded to a piece of equipment that a floating crane may pick 10 times a day, 5 to 6 days a week. We are so very lucky to have a resource like this tool forum, and even more so to have someone like T_Bone who will share his expertise with all of us. T_Bone always takes the time to explain in detail every little thing. You can lay down a picture perfect weld, but if the joint prep is wrong, or the wrong filler metal is used, or a million other things that are wrong, you just built a bomb that will get you or someone else down the line. If you have any doubts ask! Read up on joint preparation. Don�t be reasonable for building a time bomb! Hopefully T_Bone will take the time to elaborate more on this subject, as he always gives more detail than I. It�s been said here before, but I will say it again, Thanks for your input T-Bone. I�m sure with all the advice you have given here you have saved some lives or at least kept someone from getting hurt. Thanks again!
T_Bone
09-04-2004 13:21:42
 Re: So you own a welder! Now what? in reply to TonyD, 09-03-2004 05:56:21
Hi Tony,
Glad that I can help someone. Some of your questions I've answered in other threads so since I'm such a poor typist, I'm copying some info I've previous posted in my other threads.
It's very important to remove all rust and scale with-in the weldment area. It you leave rust/scale on the joint surface several things happen as the weld process occurs. It will help us to understand what happens by starting with what is a pure molten weld puddle. When the electrode is running on a clean surface, the molten weld puddle is really pure, meaning there's very few contaminates with-in the molten puddle.
I'll describe what happens inside the SMAW process as this process is the easiest to see what I'm describing in the molten weld puddle as you weld. Other weld processes are very simular with-in the molten puddle action but is a little harder to see.
With the SMAW (stick) process, the flux from the ecletrode provides a cover gas to keep the molten puddle free of oxygen and helps remove comtaminates with-in the molten puddle. If you pay close attention to the molten puddle you will observe and very liquid center that looks like a mirror. At the edge of the molten puddle on the edge of the mirror puddle, you will notice several lines forming of a different colors, more dull. Thease lines are forming to carry away contaminates along with the flux as the molten puddle cools towards the edges. In essence one could say that the center of the molten puddle is the most pure and the molten puddle edges less pure but not to say the edges of the weld are defective or weak.
Now that we know what a pure molten puddle looks like. if we pay close attention to the weld puddle then we can see contaminates form with-in the molten puddle. This would show up as a dull center puddle depending on how many contaminates the molten puddle contained. Other times you will see flecks or spots, swirl around in/on the mirror puddle, and this is the rust/scale that wasn't cleaned off during prejoint prep or discontinuties contained with-in the base metal. Thease specks/spots show up really well on X-ray flim and depending on there size and locations depends if they pass x-ray weld inspection.
Oil is carbon. When oil is left on the joint surface then the oil burns until to a carbon ash then enters into the molten puddle as carbon as the joint is welded. Too much carbon content will cause the metal to become very brittle and will most likely crack with-in the weld zone. Most oils also contain sulfur. Too much sulfur content will cause the base metal to fracture easy. This is one reason why the Titanic broke up into pieces as the base metal contained a very high sulfur content (according to a PBS TV special).
As stated, joint design has everything to do with penetration. As a general rule anything over 1/4" base metal thickness needs a bevel of approx. 45 degrees. Thats 22.5 degrees bevel on each piece on a groove weld joint. Root face should be limited to 1/8" maxmium with a 1/8" maxmium root opening. Some joint designs require less bevel and some joints require more. This would also be effected by the welding process selected.
Now that I gave a general rule of thumb (also AWS code), let me blow that therory out of the water with this example:
We have a 1/4" square butt joint weld with 100% joint penetration required with the back of the joint not accessible. As stated above we don't need a bevel, and root opening will be 1/8" and we will use a 1/8" 6010 electrode a very deep penetrating electrode.
Using 1/8" 6010 DCEP there would be no way we would achieve 100% penetration without a bevel on this joint design with out back gouging the weld which we can not do because it's not accessible. We could however achieve 100% penetration with a 30 degree beveled joint design or by using a backing plate with a 1/4" root opening.
As a weldor gains experience, it will be apparent when more or less bevel is needed for a pictular joint design for 100% penetration weld no matter what the joint design is.
Is a 100% penetration weld needed all the time? Nope, as a fillet joint weld would be good example.
T_Bone
Loren
09-04-2004 20:55:53
 Sure wish you worked at my work. in reply to T_Bone, 09-04-2004 13:21:42
Well, sort of. Wouldn't really wish that place on any prospective friend. Told the boss about all I do for welding is make things stick. "Ok, we'll have you weld then." Great. Noone there has any formal welding knowledge, only what they've learned on the job, there. It's not a good thing. I could drive you nuts with qustions.
T_Bone
09-05-2004 20:08:42
 Re: Sure wish you worked at my work. in reply to Loren, 09-04-2004 20:55:53
Hi Loren,
Ask away as that is how I learned. I was very fortuneate to work with some very skilled craftmen early in my carrer. The book learning I pursued on my own. Most of the time skill is needed more than the book learning.
T_Bone
T_Bone
09-05-2004 20:08:35
Hi Loren,
T_Bone
Davis In SC
09-03-2004 20:38:56
Tony, close calls like yours are scary !!! I still get cold chills when I think of things like that that I have seen..... I am a decent welder, but would never weld anything that I think could endanger life or limb...Best to leave that stuff to the experts, I would trust T-Bone to weld things like that. On subject of welding, I use a shop in Western NC that does micro-welding. Those guys are amazing !!! They weld under microscopes if needed, they can put a tiny dot on a part. They can place welds on dies or molds so close that often I can finish it with a stone. Regards, Davis
youngster
09-04-2004 05:16:14
 Re: So you own a welder! Now what? in reply to Davis In SC, 09-03-2004 20:38:56
i know what u mean one of my buddies can weld 2 razor blades together under the scope. thatc cool.
while were on the subject i want to weld a peice of i beam atop a post for a chain hoist any tips on how to do so.
MAC,IL
09-03-2004 07:17:26
I've welded for 40 some years off and on, but I am still not a welder. There are "many factors" to take into consideration. Reminds me of the time I hired a "welder" for the place I worked at. Was he surpeised when I brought the euip out for him to show me what he could do. Come to find out, he was a welder, worked at a car plant and all he did was punch buttons.
Frank (N.Mi.)
09-03-2004 15:12:38
 Re: So you own a welder! Now what? in reply to MAC,IL, 09-03-2004 07:17:26
Reminds me of a story my dad told me...A couple of his 'ner do well' aquaintances saw an add in the paper for a welding position. Of course they didn't know anything about welding but they COULD talk a good line of b.s....So they get to the jobsite and go up to the supervisor "We're welders and we'd both like to apply for the position." Supervisor says "OK, not afraid of heights are ya?" "Oh no, no problem there." they say. "Allright great!" says super, "take this mounting bracket and weld it to the top center of that tower over there."(motions toward a sixty foot tower). The two "welders" look at tower "Yeah sure but how are we supposed to get to the top of the tower? Crane or something?" Super motions toward a pile of bar stock "Just take some of these and weld your steps as you go up!"..... ..... ..... ..... .It was about here that the would be welders "fessed up".
TheRealRon
09-03-2004 07:06:45
Welding is a skill used by millwrights, fabricators, mechanics, etc. In that sense, it's just a tool, like a hammer. If you don't understand fabrication, for example, you have no business fabricating anything, with or without welding. This is exactly why the master/apprentice programs has been around for hundreds of years... those with the knowledge and experince teach those who don't.
But sadly far too mnay people lack anything resembling common sense. It's great to ask questions but in the end you are responsible for your own actions. Therefore, whether it's T_Bone, me, or anyone else you get information from, use your own common sense. In other words, don't let anyone else do your thinking for you.
george md
09-03-2004 22:20:53
 Re: So you own a welder! Now what? in reply to TheRealRon, 09-03-2004 07:06:45
Ron, after your insults to T-Bone several weeks
ago , don't you ever put yourself if his league.
george
TheRealRon
09-04-2004 01:14:29
 Re: So you own a welder! Now what? in reply to george md, 09-03-2004 22:20:53
You are a liar!
TonyD
09-03-2004 09:34:11
Hi Ron. I couldn�t agree more! The one that use to really burn me up was divers. I�ve had a lot of commercial diver work for me in the past. They would come right out of dive school, but not know a thing about the trade, just knew how to get to the bottom. If they graduated dive school the union would let then in as journeymen. I have had some divers I would not let them go to the back of the barge and rig something with out help, but I had to let them go 200 � 300 feet down in the water all by them selves to rig something. Never seemed right to me! To a large degree welding as diving is just a tool of the trade not the whole trade it�s self. Very few people are just welders, they generally are attached to a trade with journeyman status.
Coloken
09-03-2004 06:48:40
Your point is well taken. If the weld is some part that is critical to safty..stop and think. I welded a fan blade on a Case LA fan many years ago and it ran for years, but I properly heat treated it after welding. Ski area here a few years ago welded a 12 foot ? cast wheel to a stel shaft....every farmer know you can't do that. Point is, think about what you are doing. There is alot more to good welding than just sticking parts together.
