Tool Talk Discussion Forum
Compression Tester
Phil (Maryland)
08-30-2004 20:38:30
Can someone provide me with the brand name and model of a good and inexpensive compression tester that will fit different size plug holes?
Thanks
Phil from Maryland
09-04-2004 15:08:43
 Re: Compression Tester in reply to Phil (Maryland), 08-30-2004 20:38:30
Thanks guys. I went to Pep Boys and bought the Lesle or whatever it was called. Did a compression check and have about 150# in all cylinders. I would assume that this is good correct?
Thanks
Charles (in GA)
08-31-2004 19:18:23
Go to an auto parts place, CARQUEST, FEDERATED, O'REILLY or PEP BOYS and look on the Lisle Tool boards. You will find a nice gauge,hose,stair stepped threaded end for different thread plug holes, and it will be reasonable priced. Good products.
Charles
Dan
08-31-2004 15:48:31
Got one from Harbor Freight for less than $20. I compared the reading with my Father-in-Law's $100+ tester and the results were within 2 psi.
I'll stick with the Harbor Freight model.
Good luck,
Dan
JT
08-31-2004 07:23:06
bought a gas one from NAPA for $35.00
the only reasonable diesel I found is from Briggs for about $100.00
Steve (Magnolia, TX)
08-31-2004 06:23:52
I bought one from Harbor Freight for less than $10.
I figure as long as you"re not relying on it being precise (and I"m not saying that it"s NOT precise) then it"d be fine.
It"s a gas compression gauge, by the way...
HTH
Steve
MarkB_MI
08-31-2004 02:53:34
Sears has an OK model for 25 bucks. See link below.
TheRealRon
08-31-2004 02:29:57
NAPA. Be sure you get the right one... one is for gas engines (low compression), one is for diesels (high compression).
txblu
08-31-2004 05:50:52
 Re: Compression Tester in reply to TheRealRon, 08-31-2004 02:29:57
Diesels are 400 to 500#. Gas is 80 to 170.
